Community Member
What is the voip-null0 interface?
Hi all,
I have just started in a new company and they have WhatsUp Gold monitoring their network.
We have recieved an email alert for a router voip-null0 interface going down for a couple of minutes and then back up again!
I have searched the web but I can't see what the interface is or does....I assume it has something to do with the routers voice capability but I am not sure what or why we would be monitoring it as an interface.
Any light shed on this topic would be greatly appreciated as always
David
Everyone's tags (3)
1 ACCEPTED SOLUTION
Community Member
Hi David,
According to the book "TcL Scripting for Cisco IOS" "VoIP-Null0 is purely cosmetic and will be enabled when Cisco Express Forwarding (CEF) is turned on".
Hope it helps.
Kind regards,
Andrew C.
Kind regards, Andrew C.
Community Member
Hi David,
Hope it helps.
Kind regards,
Andrew C.
Community Member
Thanks for the swift response Andrew, much appreciated
Hi David
voip-null0 is a cosmetic interface and it's automatically enabled  when ip cef is enabled.
regards
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Community Member
Thanks for the swift response Carlo, much appreciated
VIP Super Bronze
David,
Null0 interface is the graveyard for any packet sent to it. It is a virtual interface and it is where all packets sent to it  meets a horrible death! . Any traffic sent to this interface never comes back alive..To understand it better you can refer to this doc and thread
https://supportforums.cisco.com/docs/DOC-5714
https://learningnetwork.cisco.com/thread/3985
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
Thanks for the comments Aokanlawon,
I understand the concept of a standard Null 0 interface, but my question was referring to the voip-null0 interface which i couldn't see the point of .  I have however had a read of the links you posted and gave myself a little refresher so that was nice
Now I know the voip-null0 interface is cosmetic I am going to remove it as a monitored interface within WhatsUp Gold.  However I still don't know how it failed to respond to icmp ping if it's logical and the router and all other interfaces remained up!
As I understand it this is a one off
Thanks again,
David
Community Member
Most likely it wasn't an ICMP-ping issue but SNMP-get issue ) I mean that your monitoring system probably collects the snmp-status of your gateway and reacts on the loss of the voip-null0 interface (due to CEF off/on for example) like you've mentioned.
Kind regards,
Andrew C.
1019
