Community Member
What licences are required to use Linksys SIP handsets on CUCME
Hi There,
Can someone out there clarify what licences I require if I use SIP handsets on CCME, I would like to use the Linksys SPA962 SIP handset. Has anyone used these handsets, if what do you think of them?
Stafford
1 REPLY
Re: What licences are required to use Linksys SIP handsets on CU
These Linksys phones aren't officially supported in CME yet, so I'm not sure what type of licensing you would need. You can probably get them to work, but there's no official support.
It would most likely be just the SIP CME License, which I admittedly know nothing about.
hth,
nick
202
