Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
What problems ?? IF callmanager 4.2 is changed from workgroup to domain???
HELLO
Does anybody know, what are the problems if I change the callmanager 4.2 from workgroup to the domain?
I changed because my client insist to do it, but I don?t really know the main reason no to do it.
ANY HELP WILL BE VERY APRECIATED.
REGARDS
WALTER
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: What problems ?? IF callmanager 4.2 is changed from workgrou
Hi Walter,
Here is the Cisco reasoning from the 4.x SRND Guide;
Adding Cisco Unified CallManager Servers to a Domain
Adding the Cisco Unified CallManager servers to a Microsoft Windows domain differs substantially from integrating Cisco Unified CallManager with an external directory. Although these operations do not exclude each other, they are completely independent and have different implications:
Adding Cisco Unified CallManager servers to a Microsoft Windows Active Directory (AD) domain could cause domain policies to be applied to the Windows 2000 Server operating system, and the addition affects only the management of the Cisco Unified CallManager server itself.
Integrating Cisco Unified CallManager with an external directory (such as Microsoft Active Directory or Netscape Directory Server) causes Cisco Unified CallManager to store all its user information and preferences in that directory, but it does not affect management of the Cisco Unified CallManager server itself.
Cisco recommends that you keep Cisco Unified CallManager servers as **workgroup servers**. However, if you want to add the servers to a domain, avoid applying domain policies to the server that could interfere with its normal operation.
From this good SRND doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_chapter09186a00806e8c04.html#wp1067012
Hope this helps!
Rob
Hi Walter,
Hope this helps!
Rob
Thank very much for your help ROB.
Walter Flores
121
