What's Conference Max SESSIONS here meaning about DSPFarm configuration?
I wanna what's Conference Max SESSION here meaning? Does it mean the qty of the conference(not the participant)? If yes, is it the qty under G711 or G729?
dspfarm profile 1 conference
associate application SCCP
maximum sessions 12
And, does MTP and transcode must be configed? also what's the meaning about the max session for MTP and Transcode?
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: What's Conference Max SESSIONS here meaning about DSPFarm co
That config you posted does not tell me what codecs you are using...
You will need to look under your dial-peers if you are using h.323 or under the region settings on your IP phones if you are using MGCP to know which codecs you are using.
To know the amount of dsps required for 12 conference sessions.. You can use the cisco dsp calculator to calculate this..
Its located here...
http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl
Finally for oyu to have 12 sessions configured that implies that you have enough dsps to handle them, otherwise cisco router will not allow you to configure this number of sessions if you do not have the required dsps
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
With callmanager you can have up to 8 participants per each conference sessions. So 12 conference sessions implies a maximum of 96 participants.
This has nothing to do with codecs...
MTP xcoding is only necessary of you need xcoding resources. That is if you want to convert from one codec to another..eg If you make a call from the pstn which uses G.711 and the call is going to an IP phone which uses G.729. You will then need a xcoder to convert from G.711 to G.729
You do not necessarily need to have Xcoder for conferencing to work.
Thanks.
But Cisco document said, C5510 (G.711 only) can support Max 8 Conferences, each can support 8 participants, and C5510 (G.729a/G.729) only can support Max 2 Conferences, each can support 8 participants.
My question is , according to my configuration attached above, I'm confusing the Max Session 12 means 12 G711 conference or 12 G729 conference. You know different QTY dsp needed for different code conference , I'm also confusing how many dsp needed with max seesion 12 here?
VIP Super Bronze
Its located here...
1554
