Community Member
What SW is required to configure H323 Gateway in a 2801?
What SW is required to configure H323 Gateway in a 2801. Will advanced IP services allow H323 Gateway to be be configured on a 2801? Is the same true for a 2811?
1 REPLY
VIP Purple
Re: What SW is required to configure H323 Gateway in a 2801?
You will need a minimum of IP Voice. Advanced IP Services would definitely do the job. This will work for 2801 or 2811.
Hope this helps. If so, please rate the post.
Brandon
98
