What was the feature's name?
You select the extension and give the called party and it gives you if you have authorization to make the call or not. From where or which program can we do this in CCM 6.1?
thx
1 REPLY
Re: What was the feature's name?
do you mean CMC and FAC??
java
if this helps, please rate
java
www.cisco.com/go/pdi
99
