Community Member
When dial number Ring Once then Fast Busy
I'm trying to troubleshoot why I'm getting a Busy when dial a my backup line phone number.  I have a VOIP telephone system and 2 backup analog lines connected to a FXO port 0 and 1 on a 2651XM router, I'm testing a backup line from my router.  So I ran the command csim start 94231294 ...This allows you to determine whether you can properly go offhook from the router to the PSTN, send digits, and complete a call to the destination phone.  So typed in my cell phone as the number and successfully received the call.  But when i try and call the number back.  The number rings Once and then I receive a FAST BUSY.  Do anyone have any idea why this would happen?  Here's a partial of my router configs..  Thanks in advance!
call rsvp-sync
voice-port 1/0/0
no comfort-noise
connection plar 1999
voice-port 1/0/1
no comfort-noise
voice-port 1/1/0
voice-port 1/1/1
voice-port 50/0/158
voice-port 50/0/159
voice-port 50/0/160
voice-port 50/0/161
voice-port 50/0/162
voice-port 50/0/163
voice-port 50/0/164
voice-port 50/0/165
voice-port 50/0/166
voice-port 50/0/167
voice-port 50/0/168
voice-port 50/0/169
voice-port 50/0/170
voice-port 50/0/171
voice-port 50/0/172
voice-port 50/0/173
voice-port 50/0/174
voice-port 50/0/175
voice-port 50/0/176
voice-port 50/0/177
voice-port 50/0/178
voice-port 50/0/179
voice-port 50/0/180
voice-port 50/0/181
voice-port 50/0/182
voice-port 50/0/183
voice-port 50/0/184
voice-port 50/0/185
voice-port 50/0/186
voice-port 50/0/187
voice-port 50/0/188
voice-port 50/0/189
voice-port 50/0/190
voice-port 50/0/191
voice-port 50/0/192
mgcp profile default
dial-peer cor custom
dial-peer voice 100 pots
destination-pattern 9T
port 1/0/0
dial-peer voice 101 pots
preference 1
port 1/0/1
dial-peer voice 911100 pots
destination-pattern 911
port 1/0/0
prefix 911
dial-peer voice 911101 pots
preference 1
port 1/0/1
prefix 911
dial-peer voice 2000 voip
destination-pattern [1-8]...
session target ipv4:10.1.200.11
no vad
dial-peer voice 2001 voip
preference 1
session target ipv4:10.1.200.10
no vad
dial-peer voice 9000 voip
no vad
dial-peer voice 9001 voip
preference 1
no vad
call-manager-fallback
ip source-address 192.168.96.1 port 2000
max-ephones 48
max-dn 192
1 ACCEPTED SOLUTION
VIP Purple
Re: When dial number Ring Once then Fast Busy
Is 1999 a valid DN to receive the call? Are your voip dial peers using the correct codec (g.729 by default)? Correct codec configured in CUCM?
Hope this helps.
Brandon
VIP Purple
Hope this helps.
Brandon
Community Member
Hi Brandon,  Thanks for your prompt response.  I'm so new to the voice side.  Can you explain what is a connection plar 1999 (is 1999 an extension DN (directory number?) and how can I check if is 1999 is capable of receive a call?  Would that be in the CUCM?
And what would be the correct codec to use?  Thanks so much... I'm also researching the cisco website... I do appreciate your help...
Community Member
Hi Brandon,
Thanks for your help.  The problem is resolved now.
Community Member
So what was the fix. I am having the same issue.
2210
