03-12-2012 01:15 PM - edited 03-16-2019 10:05 AM
Hi ,
I am using the Cisco 2911 as the voice gateway with CME installed.I having 2 E1 connected and I am using one line as the board line and the other is my direct line.
I am having 12 IP phone are installed,my IP phone is 7961.
When ever I call internal Ip phone, they are able to see my extension number,whenever I call the outsider's mobile number,they can see the board number instead of my direct line number.
How to resolve this?
03-12-2012 01:23 PM
Who is sending the caller ID on outbound calls, you or your telco?
03-12-2012 01:25 PM
please post your cme config and debug isdn q931 and let us know the main number and the number you are calling from.
03-12-2012 08:18 PM
Check with your service provider if they are dropping your calling number id and putting the board line number as calling number.
This may happen if calling number do not match the service providers range.
Ronak Patel
03-12-2012 08:44 PM
Hi the below is the configuration.
ZIMEGW01#sh run
Building configuration...
Current configuration : 25068 bytes
! Last configuration change at 10:48:22 AST Mon Mar 12 2012 by zimeadmin
! NVRAM config last updated at 10:36:04 AST Mon Mar 12 2012
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname ZIMEGW01
boot-start-marker
boot system flash:/c2800nm-spservicesk9-mz.124-22.YB.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 5
logging message-counter syslog
logging buffered 51200
logging console critical
enable secret level 5 5 $1$UVJt$GPtrRaIg7G.4ejBPL89WW1
enable secret level 7 5 $1$W.rk$WjEfigng9IqZWvNAZ19Xa.
enable secret 5 $1$57SE$HDGz0v2d0BSYuk7vyijCB/
enable password 7 060506324F410A1400
aaa new-model
aaa authentication login default none
aaa accounting connection h323
action-type start-stop
group radius
aaa session-id common
clock timezone AST 3
network-clock-participate wic 2
dot11 syslog
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.102.1
ip dhcp excluded-address 192.168.102.240 192.168.102.254
ip dhcp pool phone
network 192.168.102.0 255.255.255.0
default-router 192.168.102.1
option 150 ip 192.168.102.1
no ip bootp server
no ip domain lookup
ip domain name zime.biz
ip name-server 193.188.97.212
ip name-server 193.188.97.209
no ipv6 cef
isdn switch-type primary-net5
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer
supplementary-service media-renegotiate
supplementary-service ringback h225-info
fax protocol t38 ls-redundancy 2 hs-redundancy 2 fallback none
h323
emptycapability
no h225 timeout keepalive
h245 passthru tcsnonstd-passthru
sip
rel1xx supported "rel100"
header-passing
registrar server
history-info
block 183 sdp absent
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class sip-profiles 1
request INVITE sip-header Diversion remove
voice register global
mode cme
source-address 192.168.100.250 port 5060
max-dn 3
max-pool 3
tftp-path flash:
create profile sync 2223448431245108
voice register dn 1
number 2000
allow watch
name SIP-Client
voice register pool 1
id mac 0024.8139.4A1C
voice logout-profile 1
voice translation-rule 1
voice translation-rule 9
rule 1 /^999$/ /999/
rule 2 /^9\(.*\)/ /\1/
voice translation-rule 10
voice-card 0
crypto pki trustpoint TP-self-signed-399937251
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-399937251
revocation-check none
rsakeypair TP-self-signed-399937251
username zimeadmin privilege 15 secret 5 $1$ups9$C2aXPGjm0mMd2QMEEKPXs/
username Ahmedjabber
archive
log config
hidekeys
controller E1 0/2/0
framing NO-CRC4
pri-group timeslots 1-10,16
ip tcp synwait-time 10
class-map match-all L3-to-L2_VoIP-Cntrl
match ip dscp af31
class-map match-all L3-to-L2_VoIP-RTP
match ip dscp ef
class-map match-all SIP
match protocol sip
class-map match-all RTP
match protocol rtp
policy-map EthOut
class RTP
policy-map output-L3-to-L2
class L3-to-L2_VoIP-RTP
set cos 5
class L3-to-L2_VoIP-Cntrl
set cos 3
translation-rule 1
Rule 0 40.. 4000
translation-rule 10
Rule 0 71.% 1
Rule 1 73.% 3
Rule 2 700.% 00
Rule 3 81.% 0
Rule 4 83.% 3
Rule 5 800.% 00
translation-rule 2
Rule 0 4004 17504004
translation-rule 100
Rule 5 4031 17504031
gw-accounting syslog
interface Null0
no ip unreachables
interface GigabitEthernet0/0
description $FW_INSIDE$
ip address 192.168.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no ip mroute-cache
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip address 192.168.20.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface GigabitEthernet0/1.100
description ** Server VLAN$
encapsulation dot1Q 100
ip address 192.168.100.250 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface GigabitEthernet0/1.102
description ** Voice VLAN **$FW_INSIDE$
encapsulation dot1Q 102
ip address 192.168.102.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
service-policy output output-L3-to-L2
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving T302 500
isdn incoming-voice voice
no cdp enable
interface Service-Engine1/0
description "C
ip unnumbered GigabitEthernet0/1.100
no ip redirects
no ip unreachables
no ip proxy-arp
service-module ip address 192.168.100.249 255.255.255.0
service-module ip default-gateway 192.168.100.250
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.100.254
ip route 172.16.40.0 255.255.255.0 192.168.100.251
ip route 192.168.2.0 255.255.255.0 192.168.20.253
ip route 192.168.100.249 255.255.255.255 Service-Engine1/0
ip route 192.168.101.0 255.255.255.0 192.168.100.254
ip http server
ip http access-class 1
no ip http secure-server
ip http path flash:
logging facility local6
logging server-arp
logging 192.168.100.5
access-list 1 remark HTTP Access-class list
access-list 1 remark SDM_ACL Category=1
access-list 1 permit 192.168.100.0 0.0.0.255
access-list 1 permit 192.168.101.0 0.0.0.255
access-list 1 permit 192.168.102.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.255
access-list 1 permit 172.16.40.0 0.0.0.255
access-list 1 deny any
access-list 60 permit 192.168.100.28
access-list 100 remark VTY Access-class list
access-list 100 remark SDM_ACL Category=1
access-list 100 permit ip 192.168.100.0 0.0.0.255 any
access-list 100 permit ip 192.168.101.0 0.0.0.255 any
access-list 100 permit ip 192.168.102.0 0.0.0.255 any
access-list 100 permit ip 10.1.10.0 0.0.0.255 any
access-list 100 deny ip any any
snmp-server community zayani_zime RO 60
snmp-server source-interface informs GigabitEthernet0/1.100
snmp-server enable traps snmp linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server host 192.168.100.28 version 2c zayani_zime
tftp-server flash:ATA030204SCCP090202A.zup
control-plane
voice-port 0/0/0
cptone SA
timeouts interdigit 3
timeouts call-disconnect 1
timing hookflash-out 500
description ### 17212756 ###
caller-id enable
voice-port 0/0/1
cptone SA
description ### 17225111 ###
caller-id enable
voice-port 0/0/2
cptone SA
description ### 17229033 ###
caller-id enable
voice-port 0/0/3
caller-id enable
voice-port 0/2/0:15
timeouts interdigit 5
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
connection plar opx 6001
caller-id enable
voice-port 0/1/3
caller-id enable
ccm-manager fax protocol cisco
mgcp fax t38 ecm
dial-peer cor custom
name local
name international
dial-peer cor list International-calls
member local
member international
dial-peer cor list Local-call
member local
dial-peer voice 66 voip
description ** cue voicemail pilot number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 6000
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 67 voip
description ** cue auto attendant number **
destination-pattern 6001
codec g711ulaw
no vad
dial-peer voice 11 pots
incoming called-number 40..
direct-inward-dial
port 0/2/0:15
dial-peer voice 10 pots
destination-pattern 1.......
translate-outgoing calling 1
port 0/2/0:15
forward-digits all
dial-peer voice 12 pots
destination-pattern 3.......
port 0/2/0:15
forward-digits all
dial-peer voice 13 pots
destination-pattern 8.......
port 0/2/0:15
forward-digits all
dial-peer voice 20 pots
destination-pattern 91.......
port 0/2/0:15
forward-digits 8
dial-peer voice 21 pots
destination-pattern 93.......
port 0/2/0:15
forward-digits 8
dial-peer voice 70 pots
destination-pattern 71.......
port 0/0/0
forward-digits 8
dial-peer voice 71 pots
destination-pattern 73.......
port 0/0/0
forward-digits 8
dial-peer voice 80 pots
destination-pattern 81.......
port 0/0/1
forward-digits 8
dial-peer voice 81 pots
destination-pattern 83.......
port 0/0/1
forward-digits 8
dial-peer voice 14 pots
corlist outgoing International-calls
destination-pattern 00T
port 0/2/0:15
forward-digits all
dial-peer voice 50 pots
destination-pattern 5T
translate-outgoing called 10
no digit-strip
port 0/0/2
forward-digits 8
dial-peer voice 7777 pots
destination-pattern 7.......
port 0/2/0:15
forward-digits 8
dial-peer voice 181 pots
destination-pattern 181
port 0/2/0:15
forward-digits 3
dial-peer voice 175 pots
port 0/2/0:15
forward-digits all
dial-peer voice 196 pots
destination-pattern 196
port 0/2/0:15
forward-digits 3
dial-peer voice 1712 pots
port 0/2/0:15
forward-digits 8
dial-peer voice 7707 pots
destination-pattern 77070705
port 0/2/0:15
forward-digits 8
dial-peer voice 6666 voip
destination-pattern 600.
codec g711ulaw
no vad
dial-peer voice 2000 voip
description SIP Trunk to VX Gateway
translation-profile outgoing VX-gateway
destination-pattern 2...
b2bua
session target ipv4:192.168.100.66
session transport udp
incoming called-number 2...
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 4030 voip
description Exchange Subscriber Access Number
destination-pattern 4030
incoming called-number 4030
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 4020 voip
description Exchange Auto-attendant Number
destination-pattern 4020
incoming called-number 4020
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 4040 voip
description Conference Dial-in Number
destination-pattern 4040
incoming called-number 4040
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 121 pots
destination-pattern 121
port 0/2/0:15
forward-digits all
dial-peer voice 711 pots
sip-ua
telephony-service
em logout 12:0
max-ephones 96
max-dn 192
ip source-address 192.168.102.1 port 2000
calling-number initiator
system message ZIME Inspiring Technology
url services http://192.168.100.249/voiceview/common/login.do
url authentication http://192.168.100.250/voiceview/authentication/authenticate.do
load 7914 cmterm-7914-sccp.5-0-4
load 7906 SCCP11.8-4-2S
load 7941 SCCP41.8-4-3S
load 7961 SCCP41.8-4-2S
time-zone 31
time-format 24
date-format dd-mm-yy
voicemail 4030
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
web admin system name venkat secret 5 $1$/Y.7$BL1wOfM13yFjXHd1YoEAm0
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
after-hours block pattern 1 00T
after-hours block pattern 2 900T 7-24
after-hours day Sun 18:00 07:59
after-hours day Mon 18:00 07:59
after-hours day Tue 18:00 07:59
after-hours day Wed 18:00 07:59
after-hours day Thu 18:00 07:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
create cnf-files version-stamp 7960 Feb 02 2012 13:09:08
ephone-dn 1 dual-line
number 4002
label 4002
description Vivek
name Vivek
ephone-dn 2 dual-line
number 4003
label 4003
description Biji Thomas
name Biji Thomas
ephone-dn 3 dual-line
number 4027
label 4027
description Rajesh
name Rajesh
corlist incoming Local-call
corlist outgoing Local-call
ephone-dn 4
number 4004 secondary 17504004
label 4004
description FAX LINE
name FAX
translate calling 2
translate called 2
ephone-dn 5 dual-line
number 4000
label 4000
description Receptionist
name Receptionist
call-forward busy 6001
call-forward noan 6001 timeout 20
hold-alert 30 originator
ephone-dn 6 dual-line
number 4031 secondary 17504031
label Sushil 4031
description Sushil
name Sushil
translate calling 100
translate called 100
ephone-dn 7
number 4035
label 4035
description SANJAY
name SANJAY
ephone-dn 8
number 4042
label 4042
description Venkat & Austin
name Prosoft-2
call-forward busy 6000
call-forward noan 6000 timeout 20
ephone-dn 9 dual-line
number 4005
label 4005
description Conference Room
name Conference Room
call-forward noan 6000 timeout 15
ephone-dn 10 dual-line
number 4015
label 4015
description BIJI THOMAS
name BIJI THOMAS
ephone-dn 11 dual-line
number 4017
label 4017
description Harsha
name Harsha
ephone-dn 12 dual-line
number 4016
label 4016
description Bassel Hammoud
name Bassel Hammoud
ephone-dn 13 dual-line
number 4018
label 4018
description Rajesh
name Rajesh
call-forward all 86589
ephone-dn 14 dual-line
number 4019
label 4019
description Moosa Al-Hindi
name Moosa Al-Hindi
call-forward busy 2019
call-forward noan 2019 timeout 10
ephone-dn 15
number 4044
pickup-call any-group
pickup-group 123
label 4044
description VEENA
name Veena
ephone-dn 16
number 4039
label GUEST HR
description GUEST HR
name GUEST HR
ephone-dn 17
number 4037
label 4037
description Ahmed Jabber
name Ahmed
ephone-dn 20 dual-line
number 4012
label 4012
description Ahmed Medhat
name Ahmed Medhat
ephone-dn 21 dual-line
number 4011
label 4011
description Mayur Kothari
name Mayur Kothari
ephone-dn 22 dual-line
number 4013
label 4013
description Manjunath
name Manjunath
ephone-dn 23
number 4021
label 4021
description Ahmed Morsy
name Ahmed Morsy
call-forward all 4679*
call-forward busy 2021
call-forward noan 2021 timeout 10
ephone-dn 24
number 4029
label NSG2
ephone-dn 25
number 4025
label 4025
description Mohd hussam
name M. Hussam
call-forward busy 2025
call-forward noan 2025 timeout 10
ephone-dn 30 dual-line
number 4022
label 4022
description Martin Roshan
name Martin Roshan
call-forward busy 2022
call-forward noan 2022 timeout 10
ephone-dn 31 dual-line
number 4014
label 4014
description Yasser
name Yasser
call-forward busy 2014
call-forward noan 2014 timeout 10
ephone-dn 32 dual-line
number 4024
label 4024
description Arun
name Arun
call-forward all 6123
call-forward busy 2024
call-forward noan 2024 timeout 10
ephone-dn 36
number 4036
label 4036
description Roy
name Roy
ephone-dn 41
number 4041
label 4041
description Veena
name Veena
ephone-dn 43 dual-line
number 4043
label 4043
description Vijay CV
name Vijay CV
ephone-dn 45 dual-line
number 4045
label 4045
description Deepak
name Deepak
ephone-dn 46
number 4046
label 4046
description GARVIN
name GARVIN
ephone-dn 48
number 4048
label 4048
description PS1
name PS1
ephone-dn 50 dual-line
number 4028
pickup-group 123
label 4028
description NSG-1
name NSG-1
call-forward noan 6000 timeout 40
ephone-dn 61 dual-line
number 4032
label 4032
description PSG-1
name PSG-1
ephone-dn 62 dual-line
number 4033
label 4033
description PSG-2
name PSG-2
ephone-dn 64 dual-line
number 4034
label 4034
description Sherif M.
name Sherif M.
call-forward busy 2034
call-forward noan 2034 timeout 10
ephone-dn 70 dual-line
number 4026
label 4026
description Pakash
name Pakash
ephone-dn 71 dual-line
number 4049
label FAX
ephone-dn 90
number 17212756
label 17212756
description Vivek
name Vivek
ephone-dn 91
number 17225111
label 17225111
description Neil
name Neil
ephone-dn 92
number 4061
label 4061
description test-phone
name test-phone
ephone 1
mac-address 001C.58F9.7A03
after-hours exempt
username "user02" password 12345
type 7941
button 1:1 2:90
pin 12345
ephone 2
mac-address 001F.9EAD.FDDD
after-hours exempt
username "user03" password 12345
type 7941
button 1:2 2:91
pin 12345
ephone 3
mac-address 001C.58F9.7793
after-hours exempt
username "user27" password 12345
fastdial 1 39987755 name Wife
fastdial 2 17401426 name MIL Home
fastdial 3 39297414 name MIL Mobile
fastdial 4 39912352 name Deepak
fastdial 5 39760707 name Ehssan
fastdial 6 39655349 name Neil
fastdial 7 39417084 name Biji
fastdial 8 39887789 name Arif
fastdial 9 39862983 name Chandran
fastdial 10 39281777 name Sadiq Driver
fastdial 11 39206693 name Abdulla Driver
fastdial 12 39467283 name Sushil
fastdial 13 39632702 name Sreejith
fastdial 14 39912357 name Aneesh
fastdial 15 39625338 name Aneez
fastdial 16 39901384 name Abid
fastdial 17 39930120 name Santhosh
fastdial 18 39479363 name Garvin
fastdial 19 39601405 name Subbu
fastdial 20 39900153 name Moosa
type 7941
button 1:3
pin 12345
ephone 4
mac-address 001F.9E25.AD1E
after-hours exempt
max-calls-per-button 2
type ata
button 1:4
ephone 5
mac-address 001F.9E24.2E30
type 7961
button 1:45
ephone 7
ephone 8
ephone 9
mac-address 0004.F2E3.4D9C
after-hours exempt
type 7936
button 1:9
ephone 10
mac-address 001D.705F.B0A5
username "user15" password 12345
type 7906
button 1:10
pin 12345
ephone 11
mac-address 001D.705F.AF51
username "user17" password 12345
type 7906
button 1:11
pin 12345
ephone 12
mac-address 001D.705F.B0A6
username "user16" password 12345
type 7906
button 1:12
pin 12345
ephone 13
mac-address 001D.705F.B0F5
username "user18" password 12345
type 7906
button 1:13
pin 12345
ephone 14
mac-address 001D.705F.B059
username "user19" password 12345
type 7906
button 1:14
pin 12345
ephone 15
mac-address 0021.6A39.467A
button 1:15
ephone 16
mac-address 0022.555F.4D78
type 7906
button 1:64
pin 12345
ephone 17
mac-address 001D.705F.ACCD
username "Ahmedjabbar"
type 7906
button 1:17
ephone 19
mac-address 001D.705F.AB9B
type 7906
button 1:24
ephone 20
mac-address 001D.705F.B0E7
username "user12" password 3much
fastdial 1 39076518 name Asha
fastdial 2 39417084 name Biji Thomas
type 7906
button 1:20
pin 12345
ephone 21
mac-address 001D.705F.AAC5
username "user11" password 12345
type 7906
button 1:21
pin 12345
ephone 22
mac-address 001D.705F.AB29
username "user13" password 12345
type 7906
button 1:22
pin 12345
ephone 30
mac-address 001D.705F.B0B1
username "user22" password 12345
type 7906
button 1:30
pin 12345
ephone 31
mac-address 001D.705F.AD21
username "user23" password 5181
type 7906
button 1:31
pin 5181
ephone 32
mac-address 001D.705F.B0B9
username "user24" password 12345
type 7906
button 1:32
pin 12345
ephone 40
mac-address 001D.705F.AA11
username "user35" password 12345
type 7906
button 1:7
pin 12345
ephone 41
mac-address 001D.705F.B0C9
username "user36" password 12345
type 7906
button 1:36
pin 12345
ephone 43
mac-address 001D.705F.B0A1
username "user40" password 12345
type 7906
button 1:43
pin 12345
ephone 45
mac-address 001D.705F.B0F0
username "user45" password 12345
type 7906
button 1:16
pin 12345
ephone 46
mac-address 001D.705F.ACEF
username "user46" password 12345
type 7906
button 1:46
pin 12345
ephone 47
mac-address 001D.457E.584F
username "user47" password 12345
speed-dial 6 4029
speed-dial 7 4003
speed-dial 8 4027
speed-dial 9 4015
speed-dial 10 4031
speed-dial 11 4011
speed-dial 12 4019
speed-dial 13 4046
speed-dial 14 4036
speed-dial 15 4028
speed-dial 16 4032
speed-dial 17 4033
speed-dial 18 4043
speed-dial 19 4045
type 7961 addon 1 7914
button 1:5
ephone 50
mac-address 001D.705F.AB23
after-hours exempt
username "user28" password 12345
type 7906
button 1:50
pin 12345
ephone 51
mac-address 0022.555F.4D4F
button 1:41
ephone 52
mac-address 001D.705F.AF2C
username "user21"
fastdial 1 39760707 name 1
type 7906
pin 12345
ephone 60
no multicast-moh
mac-address 000F.341F.FD94
after-hours exempt
username "user31" password 12345
type 7961
button 1:6
pin 5555
ephone 61
username "user32" password 12345
ephone 62
mac-address 001D.705F.AF26
username "user33" password 12345
type 7906
button 1:62
pin 12345
ephone 70
mac-address 001D.705F.AB80
username "user26" password 12345
type 7906
button 1:70
pin 12345
ephone 80
mac-address 001D.705F.AC40
username "user41" password 12345
type 7906
button 1:48
pin 12345
ephone 81
mac-address 001F.9EAD.FDA6
username "user42" password 12345
type 7906
button 1:8
ephone 82
mac-address 001D.705F.AD04
username "user25" password 12345
type 7906
button 1:25
pin 12345
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login authentication local_authen
transport input telnet ssh
line vty 5 15
scheduler allocate 20000 1000
ntp master
ntp server 192.168.100.250
end
ZIMEGW01#
ZIMEGW01#
03-12-2012 09:09 PM
Send us debug isdn q931 for the call which is having issue and the main number and the number you are calling from
Ronak Patel
