Community Member
when i dial 866-469-3239 from a range of extension it failed
In my ip telephony network, i got a bunch of extension 100 to 199; 200 to 299; 300 to 399; when i dial 866-469-3239 from a range of 100 to 199 it failed and but the other range 200 to 299; 300 to 399; fine ... i got callmanager express 4.1
Community Member
Re: when i dial 866-469-3239 from a range of extension it failed
Not sure of CME, but it can be achieved very easily in CM , just by adding the missing partition in the appropriate Calling Search space. Sorry, I know this is not desired answer to you. I will try my best to search one for you.
Gajanan.
Green
Whats the difference when you make a call to that number from this range and when you do it from the other ranges? (Calling number (Sending 10 digits..., sending only 4...?), calling name?)
Could you please capture 2 debug isdn q931, if using PRI from 1 working and the non-working. If not let me know which tyype of circuit you are using to the PSTN.
Community Member
Whats the difference when you make a call to that number from this range and when you do it from the other ranges? when i dial 91866-469-3239 from a range of 100 to 199 a message(can not place this call) and but the other range 200 to 299; 300 to 399;(i am able to receive a answer from 1 in Web (Meetings
and On-Demand Collaborative Applications)(conference)
i am sending the 11 digits; a copy of my config :
dial-peer voice 9866 pots
destination-pattern 91866.......
port 0/0/0:23
forward-digits 11
the type of circuit is PRI ISDN?
--isdn switch-type primary-ni
I attach the debug
Community Member
GONZALO GASCA what do you think about the debug ^
Green
As a workaround you may send the same calling party number using a translation rule.
For me Telco is the culprit.
Jul 18 14:23:50.134: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8208
Channel ID i = 0xA98397
Exclusive, Channel 23
Jul 18 14:23:52.134: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8208
Progress Ind i = 0x8288 - In-band info or appropriate now available
Jul 18 14:26:41.632: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8209
Jul 18 14:26:44.433: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8209
Cause i = 0x82FF - Interworking error; unspecified
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Jul 18 14:26:44.681: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8 callref = 0x8209
Only thing changed is the PI for progress...
but sometimes based on ANI the path to 800 can change. Lets mask them all to either a 2 or 2 number.
230
