Where are CDR exported files?
I exported CDR and CMR files with CAR but I don't know where directory CAR export it.
I tried to find *.csv files in my hard disk CCM server and I have no result.
Can anybody help me?.
1 ACCEPTED SOLUTION
Gold
Re: Where are CDR exported files?
the file would be a txt file and check c:\CiscoWebs\art\reports\OnDemand\temp folder. This should have a .txt file. The CDR file would have CDR at the end of the file name and CMR will have CMR at the end.
I hope this helps.
Green
Ok you opened CAR| CDR Menu | Export CDR|CMR |
Right Click on the link and use save as option to download the dump)
Or check: http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsa65681&Submit=Search
Which procedure you are following?
Yes. I go to CAR| CDR Menu | Export CDR|CMR |
but I have no link.
I have the screen that I add to this post and after I press the button in the image that I attached and CDR export my CDR's and CMR's but I don't know where and I can't to select where I want to save exported files..
I use CCM 4.1
Gold
I hope this helps.
139
