Community Member
Where do I set device CSS for Pilot Point? (CUCM 7.15)
I know this sounds like a silly question, but I'm trying to set the device CSS on a pilot point - not the line CSS.  It's not a drop down box when you look at the pilot point configuration.  I've found and set it before, however it appears I did not take good notes.  I remember it was sort of a backwards way to control the device without actually being in the Pilot Point configuration.  Any thoughts?
CUCM 7.15.
Everyone's tags (3)
Hall of Fame Super Silver
Re: Where do I set device CSS for Pilot Point? (CUCM 7.15)
are you referring to hunt pilot? If so there is no separate device and line, there is only one CSS. Perhaps you recall cti route point?
Community Member
No. Pilot Point.
Application - Cisco Unified CM Attendant Console - Pilot Point.
I know you don't see a CSS drop down box when you're looking at it from the Pilot Point configuration page (normal view). There is a sneaky way. I see all my other Pilot points have the device CSS set (as well as DN CSS).
Community Member
Found it.  I setup a Pilot point with device name=XXX.  I complete the DN, and hunt group stuff.  I then search for CTI route points with the device name = XXX.  I can now set the device CSS for the Pilot point.
296
