Which firmware release supports SCCP version 20?
Greetings! Just wondering if anyone knows which release of IP phone firmware supports SCCP version 20?  I've been looking through topic and in the release notes without any success.
Thanks in advance!
Everyone's tags (3)
Hall of Fame Super Gold
Re: Which firmware release supports SCCP version 20?
Why do you need SCCP ver. 20 ?
As a side note, since it appears that you are Cisco employee, I would recommend that you use the many internal resoruces available to you, to not give the impression that you have to use a public customer forum to get the answers you need.
VIP Super Bronze
I'm pretty sure version 20 will be in firmware 9.1(1) due out with the 8.5 release. I can't find documentation on what IOS version will include it for SCCP MTP support.
You may want to reach out to David Scott if you're looking for an internal build.
15.1(2)T should have support for SCCPv20.
931
