Who can help me at converter from format audio.wav and audio.au to IVR voice Prompt for Unity Express
Hello
Who can help me at converter a format from audio.wav to IVR voice Prompt for Cisco Unity Express. So when I try to upload a audio.wav of 1.65 mb at the Unity Express, I got the message like this "audio file too large, maximun size is 1 mb". I want to record a audio.wav and a audio.au  more small, How can I do that? What software can I use for recording of prompt audio for the Cisco Unity Express, with format: u-law, 8bit, mono?
I have a audio.wav  (Format: WAV Microsoft, encoding: U-Law)  and a audio.au (encoding: U-Law, Format: AU Sun/Next)
Thanks.
Hello Luis You can use also "
Hello Luis
To apply a new prompt for your AA you have two methods:-
1-Create a .wav file with the following format: G.711 u-law, 8 kHz, 8 bit, Mono. The file cannot be larger than 1 MB (about 2 minutes). After recording the greeting, use the GUI option Voice Mail > Prompts > Upload or try g to Cisco Unity Express CLI ccn copy command to copy the file in to the Cisco Unity Express system using ftp server .
2-Use the AvT on the TUI to record the greeting or prompt. Dial the AvT telephone number and select the option to record a greeting. When finished recording, save the file. AvT automatically saves the file in Cisco Unity Expres
You can try also other tool to change the your greeting " Administration via telephone (AVT) system":The Administration via Telephone System telephone user interface allows administrative users to remotely change system greetings and prompts.".So you can apply the prompt with two methods as you mentioned to record and the upload , or by system - call handler Kindly find the below link
www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/unity_exp/rel8_0/online_help/GUI_PDF/guiadmin80.pdf
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-express/53205-GMS.html
Look you can try the below link to convert for your 1st request:-
http://www.convertfiles.com/convert/audio/WAV-to-AU.html
please rate all useful information
hiAdministration via
hi
Administration via Telephone, you have to dial the number for "Prompt Management" Application.
This can be found at  Administration > Call-in Numbers
Note:-To login to Administration via Telephone,
A)you need to be a member of a group that has Administration via Telephone capability.
B)Use your own MAILBOX id and pin to login as the followingConfigure > Groups > Administration via Telephone
Hello islam.kamal Thank you
Hello islam.kamal
Thank you for you support.
I am gladed
Hi Luis is your problem
Hi Luis
is your problem solved or not?.
please do not forget to rate all useful information
 Yes. Thank you so much
Yes.
Thank you so much
Hello Did you mind to make
Hello
Did you mind to make correct answer and rate , to make useful for anyone in future has same problem?.
612
