Community Member
Why CME License?
When I have a router with IOS that suopports CME I could configure IP Telephony. Why I need the license in this case?
Re: Why CME License?
Simple, it is a licensed feature and you should buy it.
Licenses
You must purchase a base Cisco Unified CME feature license and phone  user licenses that entitle you to use Cisco Unified CME.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeover.html#wp2286954
It's a honour based license, as it was in CUCM.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
That's right and it's possible this change when using IOS 15
as features are unlocked by license files
. Not sure if/when this model for CUCME
8 is in place but I'd not be surprised if it's true for some future releases.
Community Member
Thanks Rodmont.
I see it works for IOS version 12.4 also. I could conigure the telephony service and the IP Phones could register for it.
584
