10-26-2009 02:22 PM - edited 03-15-2019 08:14 PM
10-26-2009 06:51 PM
I hope this answers....
Music on hold allows users to place calls on hold with music that a streaming source provides. Music on hold allows two types of hold:
â¢User hold-The system invokes this type of hold when a user presses the Hold button or Hold softkey.
â¢Network hold-This type of hold takes place when a user activates the transfer, conference, or call park feature, and the hold automatically gets invoked.
10-26-2009 06:53 PM
To add or change the MOH you need to do the following:
1. Obtain the audio file for MOH (.wav or mp3).
2. Drop your audio file into:
(depending on ccm version)
C:\Program Files\Cisco\MOH\DropMOHAudioSourceFilesHere or
C:Cisco\DropMOHAudioSourceFilesHere
3. CCM > Service > Media Resource > Music On Hold Audio Source
MOH Audio Stream Number = chose a number that is not in use, see the
left hand screen to
see the numbers in use
MOH Audio Source File = select the file you want
MOH Audio Source Name = use the same name as above
Repeat = check
4. CCM > System > Device Pool > select device pool of phones you want to
change
> "User Hold MOH Audio Source" and "Network Hold MOH Audio Source" = change
to file you
Want
10-28-2009 04:35 AM
Thanks but I dont have the option for user and network in the device pool. Only the Media Resource Group.
I have set the network and user source on the end device and it still has the wrong MoH for parks.
So I am trying to set up a different MRGL only to find out I cant see a way to set up a second MoH server to add to it with only the audio file I want.
Which begs the question, when you have 3 files in the MoH which one will it use as a default for Park?
10-28-2009 04:58 AM
Sorry I forgot to mention I had defined user and network music at the device level without success.
Also I am on 6.1 if that makes a difference.
10-28-2009 09:08 AM
Cisco created something called Common Device Profile in 4.2 onwards and then removed it at CUCM 5 as 5 was based upon CCM 4 which did not have the profile and reapplied it again later as 6 is based upon 4.2. onwards - If I remember correctly. You used to have the common device profile at a DP level as well as at Device Level ???? however now at 6.X is seems to have been removed and only applied at the device level. The ideal is that a device can have the MOH settings either per device or via a Common profile so if a department, building requires a change of MOH, Hold etc then by assigning different profiles across the locations, buildings etc allows to change them in groups. By default there is no Common Device Profile
10-28-2009 11:41 AM
Interesting, and I thought for a second you had it.
Confirmed there is no device profile setting for the DP, so the only place the user/network MoH is defined is the actual device.
So I dont quite understand with the User and Network sources set to the same thing why am I getting the correct one on user hold and the system default on call parks?
It almost acts like a code bug.
