why don't we use tftp-server flash: for the phone config files.
Reprovoid
Hi.
  I was wondering how the phone config files are downloaded via TFTP If we don't specify tftp-server flash: for each file like we do with the firmware etc.
   Is It enabled by default for the config files when we use the cme router as the tftp server ?
2 Accepted Solutions
yahsiel2004
Level 7
Level 7
From the telephony-service by default when you put the "create cnf-files" command the default location is flash. You could change this.
Yosh
Sent from Cisco Technical Support Android App
HTH Regards, Yosh
Anthony Holloway
Unfortunately, Yosh did not answer your question.
Whether the default location is in memory or flash:, the phones still need their configuration files hosted by the tftp-server command.  The reason you as the administrator do not have to enter it, is that the CME software does it for you.
Compare these two commands:
show run | include tftp-server
show telephony-service tftp-bindings
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/command/reference/cme_cr/cme_s2ht.html#wp1040639
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
yahsiel2004
Level 7
Level 7
Yosh
HTH Regards, Yosh
Thanks! That clears that up.
Anthony Holloway
Anthony Holloway
Hi. I checked the tftp-server files In the run output but they're not In there. They are shown In the tftp-bindings command however. Why Is that ?
Edited: Silly reply.You Just explained to me why that Is !
UC540#sh run | include tftp-server
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/50x-30x/spa50x-30x-7-4-8a.bin alias spa50x-30x-7-4-8a.bin
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
--More--         tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
--More--         tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
--More--         tftp-server flash:/ringtones/Pop.raw alias Pop.raw
--More--         tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
--More--         tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
--More--         tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
--More--         tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
--More--         tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
--More--         tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
--More--         tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
--More--         tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
--More--         tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
--More--         tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
--More--         tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
--More--         tftp-server flash:/Desktops/CampusNight.png
--More--         tftp-server flash:/Desktops/TN-CampusNight.png
--More--         tftp-server flash:/Desktops/CiscoFountain.png
--More--         tftp-server flash:/Desktops/TN-CiscoFountain.png
--More--         tftp-server flash:/Desktops/CiscoLogo.png
--More--         tftp-server flash:/Desktops/TN-CiscoLogo.png
--More--         tftp-server flash:/Desktops/Fountain.png
--More--         tftp-server flash:/Desktops/TN-Fountain.png
--More--         tftp-server flash:/Desktops/MorroRock.png
--More--         tftp-server flash:/Desktops/TN-MorroRock.png
--More--         tftp-server flash:/Desktops/NantucketFlowers.png
--More--         tftp-server flash:/Desktops/TN-NantucketFlowers.png
--More--         tftp-server flash:Desktops/320x212x16/List.xml
--More--         tftp-server flash:Desktops/320x212x12/List.xml
--More--         tftp-server flash:Desktops/320x216x16/List.xml
--More--         tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
--More--         tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
--More--         tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
--More--         tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
--More--         tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
--More--         tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
--More--         tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
--More--         tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
--More--         UC540#
UC540#sh telephony-service tftp-bindings
tftp-server system:/its/united_states/7960-tones.xml alias United_States/7960-tones.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/7960-font.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/7920-font.xml
tftp-server system:/its/united_states/7960-dictionary.xml alias English_United_States/7960-dictionary.xml
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/7960-kate.xml
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/7920-kate.xml
tftp-server system:/its/united_states/SCCP-dictionary.xml alias English_United_States/SCCP-dictionary.xml
tftp-server system:/its/XMLDefault504G.cnf.xml alias SEPECE1A9CC4E2C.cnf.xml
tftp-server system:/its/XMLDefault504G.cnf.xml alias SEP58BFEA109671.cnf.xml
tftp-server system:/its/XMLDefault504G.cnf.xml alias SEP58BFEA11762C.cnf.xml
tftp-server system:/its/XMLDefault504G.cnf.xml alias SEPCCEF485E2AA8.cnf.xml
tftp-server system:/its/XMLDefault504G.cnf.xml alias SEPCCEF485E2B9E.cnf.xml
tftp-server system:/its/XMLDefault504G.cnf.xml alias SEPE02F6D62E861.cnf.xml
tftp-server system:/its/XMLDefault504G.cnf.xml alias SEPCCEF485E2CE7.cnf.xml
tftp-server system:/its/XMLDefault504G.cnf.xml alias SEPECE1A9CC4E1C.cnf.xml
tftp-server system:/its/XMLDefault504G.cnf.xml alias SEP58BFEA1096C4.cnf.xml
--More--         tftp-server system:/its/XMLDefault504G.cnf.xml alias SEPCCEF485E2CF4.cnf.xml
--More--         tftp-server system:/its/XMLDefault504G.cnf.xml alias SEPCCEF485E2D25.cnf.xml
--More--         tftp-server system:/its/XMLDefault504G.cnf.xml alias SEPCCEF485E2E11.cnf.xml
--More--         tftp-server system:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
--More--         tftp-server system:/its/XMLDefault.cnf.xml alias XMLDefault.cnf.xml
--More--         tftp-server system:/its/ATADefault.cnf.xml alias ATADefault.cnf.xml
--More--         tftp-server system:/its/XMLDefault504G.cnf.xml alias SEPCCEF485E2C37.cnf.xml
