Why i can not add over 5 OU in LDAP Directory in CCM(5.1.2)
I want to sync windows Account with Domain by LDAP.I only can add 5 OU in LDAP Directory.ccm version is 5.1.2 .
Re: Why i can not add over 5 OU in LDAP Directory in CCM(5.1.2)
Simply because the system does not allow more than 5 OUs. The system is working as designed.
As workarounds either modify the AD structure, use parent OUs or make sure the user you used to integrate only has read rights over the OUs you want to sync.
This has been asked several times before, PLEASE search NetPro for answers.
java
if this helps, please rate
java
www.cisco.com/go/pdi
thank you very much.
I am sorry. I have searched but did not find any useful result.
I have test that did not designate the ou in ldap directory, but got all users in AD,about 20 thousand.
I am not sure that can CCM5.1.2 support over 200000 end user by ldap?
VIP Super Bronze
thank you for your reply. :)
142
