why I can't see sql query results when I use CLI in CUCM 7
Dear all,
    I use the following command in CUCM 7 with CLI , and tried to get the call log with the speicifed calling number 88556859,
run sql select callingpartynumber, originalcalledpartynumber, finalcalledpartynumber,datetimestamporigination from car:tbl_billing_data where callingpartynumber like  '88556859'
    but I get no results from the output ,following is the output:
admin:run sql select callingpartynumber, originalcalledpartynumber, finalcalledpartynumber,datetimestamporigination from car:tbl_bil
callingpartynumber originalcalledpartynumber finalcalledpartynumber datetimestamporigination
     can any one tell me why there is no any output , the command looks no error, thank you very much!
1 REPLY
Because even if the query is correct what you're looking for cannot be found in the DB.
There are no entries for callingpartynumber like   '88556859' in your DB
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
234
