Community Member
why my 6961 cisco phone wont dial out
Hi All
I installed a new cisco  6961 phone into a CME 8.0 but the phone wont dial outside callls.the phone showed on the screen when  is dialing its own extension.then it finish the call.
I hit 9 and I got tone. the phone register.
any recomendations.
Everyone's tags (1)
1 ACCEPTED SOLUTION
No one has any idea of what your configuration looks like, how could someone tell you whether you need a translation rule or not???
If someone should know whether you need one or not, that would be you, who are familiar with your CME config.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Do you have dial-peers and a PSTN connection??
Do other phones work?
java
java
Community Member
Hi Jaime
Thanks for the respond, yes dial peers are set up, I try to do here is just to add a new phone with anextension.
I dont thing I need a new transelation rule is it?
I will double check my settings again.this an example what I did; see at the botttom
ephone-dn  81  dual-line
number 8081
ephone  31
mac-address 0FF7.58E7.0E01
type 6961
button  1:81
java
java
484
