¿why my router uses my gatekeeper for local calls?
Hi all,
I have a Gatekeeper to interconnect all the non voip sites my company has.
On one branch I already implemented full VoIP, I erased all dial-peers pointing to my GK to has RAS command.
But I still getting calls informacion on GK with the command:
#show gatekeeper calls.
Endpt(s): Alias        E.164Addr     CallSignalAddr  Port  RASSignalAddr   Port
   src EP: 805243535    805243535
   dst EP: lag3825      97336358 (local)     10.252.183.1    1720  10.252.183.1    52639
   src EP: 805245205    805245205
   dst EP: lag3825      97221633 (local)     10.252.183.1    1720  10.252.183.1    52639
lag3825# show voice call statu
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0x3BC06    EDC  0x686A2CC4 0/1/0:0.3        0/5:2   805245705  g711ulaw       121/3000
0x3BC09    3C13 0x686BABD4 0/1/1:0.3        0/2:4  *97221633   g711ulaw       3000/121 <--
0x3BC4B    1114 0x686BABD4 0/1/1:0.4        0/3:3  *97336358   g711ulaw       3000/121 <--
0x3BC4C    F66  0x686A2CC4 0/1/0:0.1        0/4:2   805245221  None           121/3000
Call Flow from call manager.
  • Call Flow
    • TranslationPattern :Pattern=
    • Route Pattern :Pattern= 9XXXXXXX
      • Positional Match List = 97221633
      • DialPlan =
      • Route Filter
      • Require Forced Authorization Code = No
      • Authorization Level = 0
      • Require Client Matter Code = No
      • Call Classification =
      • PreTransform Calling Party Number = 1000
      • PreTransform Called Party Number = 97221633 <--
      • Calling Party Transformations
      • ConnectedParty Transformations
      • Called Party Transformations
    • Route List :Route List Name= Lag_PSTN_gw <--
Dial-peers on gateway
dial-peer voice 121 pots
destination-pattern 9T
incoming called-number .
direct-inward-dial
port 0/1/1:0
no register e164
the Fa0/0 interface is configured to register with the Gatekeeper, but only THAT, I cannot  find a answer for this.
reggards.
  • IP Telephony
Everyone's tags (6)
Hall of Fame Super Silver
What is listed in Lag_PSTN_gw RL?
Can you provide "debug voice dialpeer"?
Chris
Lag_PSTN_gwRL I have only listen My route group who has the h323 router for calls. (IP)
Debug DIAL-PEER.
Aug 22 16:07:22: //-1/801E6A739711/DPM/dpAssociateIncomingPeerCore:
   Calling Number=805245205, Called Number=90448711392809, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=3000
Aug 22 16:07:22: //-1/801E6A739711/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=90448711392809, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=90448711392809
   Result=Success(0) after DP_MATCH_DEST
Aug 22 16:07:22: //-1/801E6A739711/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=126
     2: Dial-peer Tag=121
   Result=SUCCESS(0)
Aug 22 16:07:22: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=90448711392809, Called Number=90448711392809, Peer Info Type=DIALPEER_INFO_SPEECH
Aug 22 16:07:22: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Aug 22 16:07:22: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=90448711392809, Called Number=, Voice-Interface=0x0,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Aug 22 16:07:30: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=805245205, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=805245205
Aug 22 16:07:30: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3000
     2: Dial-peer Tag=3001
   Result=SUCCESS(0)
Aug 22 16:07:31: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=805243200, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=805243200
Aug 22 16:07:31: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   Calling Number=, Called Number=92040758, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=92040758
   Result=SUCCESS(0)
     1: Dial-peer Tag=121
Aug 22 16:07:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 22 16:07:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
interface Loopback6
description UNITY y SRST
ip address 10.252.183.1 255.255.255.0
ip pim sparse-dense-mode
h323-gateway voip interface
h323-gateway voip id gk2 ipaddr 10.48.1.56 1719 priority 120
h323-gateway voip h323-id lag3825
h323-gateway voip tech-prefix 8
h323-gateway voip bind srcaddr 10.252.183.1
That is the configuration of my Interface.
¿Do you think I could eliminate the GK registration configuration without affect the service?
reggards.
What is dial peer 126? Can you post it?
Also, post dial peers 3000 and 3001.
Chris
238
