Will configuration lost if i use Recovery CD to fix file system in CUCM9.1.2?
Hi All,
I have new installation for BE6K, some services are not working after i run password recovery to reset securtiy password, i tried to do DRS backup and BAT, but both fail. if i use recovery iso to fix problem, will all configuration lost? any advoice is appriciated.
please see attached picture.
1 ACCEPTED SOLUTION
VIP Purple
[+5] to Tony. You can use
[+5] to Tony.
You can use Recovery Disk.Nothing is going to be lost.
I doubt this could be a bug
pwrecovery tool does not update the internal user passwords
CSCug92142
Symptom:
Changing the security password using pwreset results in database replication going down.
file tail /cm/log/informix/ccm.log logs similar lines
09:05:12 Password Validation for user [dblpm] failed!
09:05:12 Check for password aging/account lock-out.
09:05:12 listener-thread: err = -952: oserr = 0: errstr = dblpm@CCM[CCM]: User (dblpm@CCM[CCM])'s password is not correct for the database server.
Conditions:
Fresh install of CM 9.1.1 or 9.1.1a
Change the security password using the pwrecovery method
Workaround:
Contact TAC for workaround
regds,
aman
The Recovery Disk is meant to
The Recovery Disk is meant to repair the file system. After using it, the recommendation is to do a full system backup, a new install, and a restore to avoid any potential issues that may arise again.
Assuming your install isn't completely hosed, the intent of the Recovery CD is NOT to erase any of your information, but repair the underlying file system.
Good luck with the repair!
-Tony
Thanks Tony, i will try it
Thanks Tony, i will try it this morning.
VIP Purple
[+5] to Tony.
CSCug92142
Symptom:
Conditions:
Workaround:
regds,
aman
Hi Aman,Yes, this is bug, but
Hi Aman,
Yes, this is bug, but we don't have service contract, no choice to open a case. Any advice is appreciated.
VIP Purple
Hi,Try using Recovery CD
Try using Recovery CD first .If it helps great , else u need to have [ESW ]Service Contract in place to resolve the issue.
regds,
aman
Oh god, it works. Thanks Tony
Oh god, it works. Thanks Tony and Aman.
VIP Purple
Gr8...Have ESW purchased to
Gr8...
Have ESW purchased to avoid any unknown issues for which TAC assistance is reuqired.
regds,
aman
91
