Silver
windows 7 64bit connection lost with ip phone..
windows 7 64bit professional connect to ip phone (model 7945) PoE switch model : Catalyst 2960-S Series PoE 10G,connection keep dropping but its won't happen with windows 7 32bit professional,i had do basic trouble shooting
like replace do full windows update,update computer motherboard's BIOS,replace network cable,clean install win7 64bit without install any software,use another computer and laptop to test but still get the same result..connection keep dropping..
is anyone encounter this issue before ?
please help...
Thanks..
Posted by WebUser Castles Leong
Same issue, with windows 7 32 bit and 64 bit, phone 7912 and 7911.
I'm googling...
regards
Hall of Fame Super Gold
Update IOS on the switch, and check again.
today in other site, with another switch same model, same IOS; same config, same 7911 phone and same PC win 7, there are no problem, so this issue is not IOS-dependent (I presume...)
Did anyone get an answer to this or find a solution? We have the same problem within our enterprise.
Please let me know. Thanks!
636
