Windows Firewall and Attendant Console
What exceptions need to be in place to allow Attendant Console to work on a computer with the Windows Firewall enabled?
I have CM 6.1 if it makes a difference.
--Patrick
1 ACCEPTED SOLUTION
Re: Windows Firewall and Attendant Console
Patrick,
You should just need an exception for "c:\program files\cisco\unified communications manager attendant console\bin\acclient.exe"
Hope this helps.
Brandon
Patrick,
Hope this helps.
Brandon
I added that exception and it worked. Thanks.
--Patrick
143
