Windows Mobile And Jabber
As far as i know is not any plan for jabber running with windows mobile
So do you know any other voip client to work with windows mobile and CUCM?
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
I dont know of any other
I dont know of any other clients that will work but rumors are Cisco is developing a windows mobile clients.
Please rate useful posts.
Hi I found Linphone and is
I found Linphone and is working fine with CUCM
Thank you
chrysostomos
A simple google search
A simple google search "windows mobile sip client" can give you some options, no idea how apps are delivered to windows mobile, if there's an equivalent to play store/app store, search for SIP
http://www.voipvoip.com/windows-mobile/sip.html
java
if this helps, please rate
www.cisco.com/go/pdi
Any XMPP client should work
Any XMPP client should work if you just need IM.  For phone calls, you'll also need to install a SIP client.
63
