Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
wireless issues 7921 CME paging keeps dropping
Have a CME with 7921 ,7970 paging works fine to 70 from a 70 or 21 but 21 to 21 drops constantly.
The CME 4.3 and the 7921 has latest f/w.
Also wlc has f/w 4.2.130.
has anyone ran into this issue.
Phones and CME are on same subnet and same sw stack. WLC has trunk to sw stack. Multicast paging in enabled.
Silver
Re: wireless issues 7921 CME paging keeps dropping
The recommended phone firmware load for the 7921 on CME 4.3 is Cp7921g-1.1.1.
Configuring Paging:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmepage.html
7921 have correct firmware load already, paging works everywhere else except 7921 to 7921s
for example the 7971 paging works fine to 7971, paging from 7921 to 7971 works fines so paging is configured correctly.
Here's a bug ID that may be relevant: CSCsq22861
This is fixed in 12.4(15)T8 , 12.4(20)T1 and 12.4(22)T
It's not exactly your problem, but if your 7921 is on the latest firmware, 1-2-1, an IOS upgrade probably wouldn't hurt.
Otherwise, check unicast, and open a TAC case.
hth,
nick
331
