witholding MoH for select extensions
CM 4.2 - I want to prevent MoH playing for certain extensions and play out ToH instead. I think this can be acheived in the service parameter settings option but unsure if this offers the granularity i need - i.e. i think it's applicable to all. Any guidance welcome.
Re: witholding MoH for select extensions
You could set moh at the line or phone level. then you could specify certain phones only to play TOH. What you may need to do though is create a moh file that plays your TOH then add this new file to the line or phone level.
yes, thought the latter option might be the way to go. Do you know where the toh source file is held? tks
To get TOH you need to set your MOH source to none. I am not sure where the TOH comes from. You could just create a file that is dead air and just loop that continuously.
Q. How to disable Music on Hold?
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item09186a0080094766.shtml#q20
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
perseverance pays of.
Found it in the tftppath\United_Kingdom\AnnToneOnHold.wav
does the job. Tks
112
