Community Member
Without license file. Can we reinstall our CUCM7.0?
Because our system is so old. We lost license and pak.
Is there any mothed that we could export old license from CUCM?
1 ACCEPTED SOLUTION
Purple
Hi , you can use the command
Hi ,
you can use the command file list license * to check the installed license files.
you can download the same using sftp.
if u need to install on other server, send to licensing @cisco.com along with MAC address of new server.
they will provide you with new lic files.
regds,
aman
1 REPLY
Purple
Hi ,
regds,
aman
30
