Worm Line
Hi all,
Can any one tell me if its possible to configure on the callmaner a worm line. This is a line that as the folowing beahvior:
The user goes off-hook on the phone, if the user does not dial any number for 10s then the call manager dial a pre define number like a hot line.
Is this possible with same kind of configuration on the callmanager ?
Bronze
Re: Worm Line
You could configure PLAR which does similiar thing but not sure about 10 second wait time. What version of CUCM you are using?
Cheers
Ikram
Re: Worm Line
CM 6.1(2)
I have configure PLAR but the customer wants two wait a 10s.
The customer wants to :
The phone goes off-hook, if the user dial any number the callmanager makes the call but if the user does not dial any number for a 10s periode, the callmanager then places a call to a pre-define number.
Re: Worm Line
not possible to add a delay, the whole background on a PLAR is that you do not have any more matches other than the blank translation pattern and then it dials.
adding a number to the translation pattern would only cause it to be a pattern and would follow the 1st digit timeout and clear the call if nothing is dialed
the plar would only work if you leave a blank as the pattern to match
java
if this helps, please rate
java
www.cisco.com/go/pdi
595
