You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Wrong dialed number showed
In CUCM8.6, i configured a route pattern:2.XXX,just do predot and prefix 2 in called party.
In route list,i add a h323 gw,and used predot and prefix 81.
In H323 gw ,it just only one dial-peer
"destination-patt 81...$
po 0/2/0"
So, when user placed call to 2111,it should translate to 81111.
Here is the problem,when user dialed 2111, it showed "To 2111" after 1 second, it changed to "To 8111".
So how to just make it showed "To 2111" ?
  • IP Telephony
1 ACCEPTED SOLUTION
Re: Wrong dialed number showed
Add this to your H.323 VGW.
voice service voip
no supplementary-service h225-notify cid-update
Please remember to rate helpful responses and identify helpful or correct answers.
voice service voip
Wow,It worked, rate you 5 star for this!
Thank you for the nice rating and I'm glad that it solved your problem :)
143
