Wrong Number in CUCM
How do I change a wrong phone number in CUCM for End User ? I have LDAP enabled.
Thnaks
Hall of Fame Super Gold
Wrong forum, post in "IP telephony". You can move your post using the actions panel on the right.
Re:Wrong Number in CUCM
Thanks, but I'm using the apps, how do I move it, I just installed the apps now.
Sent from Cisco Technical Support Android App
Change it directly in LDAP and wait for the next LDAP sync, or re-sync manually.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Jaime,
It did sync but no changes happened.
Senan
Re: Wrong Number in CUCM
Try to empty telephone field for desired user on your LDAP. Sync manually CUCM with LDAP. Fill the telephone field on LDAP.
Sync again and it should work.
Which LDAP Server are you using?
Carlo
Please rate all helpful posts "The more you help the more you learn"
1174
