wrong time on 7970
rafael2gc
Hi all,
Why my 7970G is displaying wrong time while all others are with the right time?
I'm using ccme4.2, the load file on my 7970 is SCCP70.8-2-2SR2S, my ios is 12.4(11)XW2.
I've set the time-zone parameter on telephone-service.
This issue is driving me Crazzzzy.
Thanks in advance.
paolo bevilacqua
can you try XW4 and 8.2(2)SR4S ?
Eg. it works fine for me with 12.4(11)XJ4.
UCBNOCWAN
Rafael,
Same type of issue with CCME 4.0, but with 7911 phones. Even the updated firmware doesn't work. Only solution seems to be to upgrade the router IOS. We are planning to implement that soon in our place. I shall keep you posted if it resolves our issue.
Abhijit Das.
mohamedtag
Hello Rafael ,
I think Upgrading the 7970 Firmware to Higher Version will solve the Problem. It worked with me.
M.Tag
