Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
wrong time on 7970
Hi all,
Why my 7970G is displaying wrong time while all others are with the right time?
I'm using ccme4.2, the load file on my 7970 is SCCP70.8-2-2SR2S, my ios is 12.4(11)XW2.
I've set the time-zone parameter on telephone-service.
This issue is driving me Crazzzzy.
Thanks in advance.
Hall of Fame Super Gold
Re: wrong time on 7970
can you try XW4 and 8.2(2)SR4S ?
Eg. it works fine for me with 12.4(11)XJ4.
Rafael,
Same type of issue with CCME 4.0, but with 7911 phones. Even the updated firmware doesn't work. Only solution seems to be to upgrade the router IOS. We are planning to implement that soon in our place. I shall keep you posted if it resolves our issue.
Abhijit Das.
Hello Rafael ,
I think Upgrading the 7970 Firmware to Higher Version will solve the Problem. It worked with me.
M.Tag
129
