WS-X6608-T1 transcoding/conferencing.
We have a WS-X6608-T1 Conferencing/MTP Resource configured on a 6000 Series
CatOS switch. The ports of this module are configured to different call manager
clusters. Due to certain reasons, some ports on this module show as
unregistered. These ports also keep getting reset hence drops all conferencing calls.Kindly help.
Green
Re: WS-X6608-T1 transcoding/conferencing.
Disable the ports unused since the shares the same chipset.
set port disable X/Y
Where X is the module and Y is the port.
show module can help you to get X
I have disabled,reset and restarted the module.No Go. Have created an RMA. 3 ports on this module is getting reset acutomatically every 2 - 3 minutes. However the other ports configured to the local CCM as transcoding/Conferencing resource is working fine.It is with the remote CCM cluster that is having problems connecting to this transcoder.
136
