Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
x-lite sip extension with uc540 using cisco anyconnect
hi all,
i aconfigured cisco uc 540 with ISDN Pri and site to site trunking between two sites everything is working fine.
now i am tryning to configure sip extension on andriod phone with bria softphone with the use of cisco anyconnect
i am able to register the phones but the issue is i am not able to get the voice.
i am able to call outside my office number like mobile and interoffice also but no where voice communication not happening including the local extension.
here the log which i am getting
here 81922 is my remote site extension and 599 is the sip extension.
debug ccsip events
PRACK sip:81922@192.168.1.1:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 80.0.0.9:56150;rport;branch=z9hG4bKPjbHFsrAkeWcoAD8DZh71qGtnj3W
ez8eBV;alias
Max-Forwards: 70
From: "amin" <sip:599@192.168.1.1>;tag=du3j9gb16-nEFTzLJiAqxQ7UOxWyH58t
To: sip:81922@192.168.1.1;tag=24512460-165C
Call-ID: m9IyAUAjYlELE.saiPDwTw0v.8l-U5xV
CSeq: 27205 PRACK
RAck: 9870 27204 INVITE
Content-Length:  0
306196: //2136/39D8F726930D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
ez8eBV;alias
Date: Mon, 03 Sep 2012 12:25:08 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 27205 PRACK
Content-Length: 0
306197: Sep  3 12:25:12.198: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(0/0), Late col
lision
306198: Sep  3 12:25:12.514: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(0/0), Late col
lision
306199: Sep  3 12:25:14.398: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(0/0), Late col
lision
306200: Sep  3 12:25:14.714: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(0/0), Late col
lision
306201: Sep  3 12:25:16.918: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(0/0), Late col
lision
306202: Sep  3 12:25:18.490: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(0/0), Late col
lision
306203: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI :
SIPSPI_EV_CC_CALL_CONNECT
306204: //2136/39D8F726930D/SIP/Error/sipSPI_ipip_set_history_info_header: Not S
IP2SIP mode
306205: //2136/39D8F726930D/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_S
ESSION_REFRESH_RESP
306206: //2136/39D8F726930D/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:1
02, resp_code:200, container:8AF98D68
306207: //2136/39D8F726930D/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 ->
Setting ;screen=no ;privacy=off
306208: //2136/39D8F726930D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 80.0.0.9:56150;rport;branch=z9hG4bKPjL7-ISjrqjNPvqx2o8J2Sfy5QcH
x1nUw.;alias
CSeq: 27204 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIF
Y, INFO, REGISTER
Allow-Events: telephone-event
Remote-Party-ID: "Nisha Ninan" <sip:922@192.168.1.1>;party=called;screen=no;priv
acy=off
Contact: <sip:81922@192.168.1.1:5060;transport=tcp>
Supported: replaces
Require: timer
Session-Expires:  1800;refresher=uac
Supported: timer
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 238
v=0
o=CiscoSystemsSIP-GW-UserAgent 4294961077 6661 IN IP4 192.168.1.1
s=SIP Call
c=IN IP4 192.168.1.1
t=0 0
m=audio 18808 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
306209: Sep  3 12:25:19.118: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(0/0), Late col
lision
306210: //2136/39D8F726930D/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 ->
306211: //2136/39D8F726930D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
x1nUw.;alias
CSeq: 27204 INVITE
Y, INFO, REGISTER
acy=off
Supported: replaces
Require: timer
Supported: timer
Content-Length: 238
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
306212: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 80.0.0.9:56150;rport;branch=z9hG4bKPjFvL0c-kDb5M0myon9zY6-tkxLh
xvQvxA;alias
Max-Forwards: 70
CSeq: 27204 ACK
Content-Length:  0
306213: //2136/39D8F726930D/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x88268C98
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : YES
Calling Number           : 599
Called Number            : 81922
Source IP Address (Sig  ): 192.168.1.1
Destn SIP Req Addr:Port  : 80.0.0.9:56150
Destn SIP Resp Addr:Port : 80.0.0.9:56150
Destination Name         : 80.0.0.9
306214: //2136/39D8F726930D/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711alaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 8 (tx), 8 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 192.168.1.1
Source IP Port    (Media): 18808
Destn  IP Address (Media): 192.168.2.4
Destn  IP Port    (Media): 40362
Orig Destn IP Address:Port (Media): [ - ]:0
306215: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
xvQvxA;alias
Max-Forwards: 70
CSeq: 27204 ACK
Content-Length:  0
306216: Sep  3 12:25:22.674: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(0/0), Late col
lision
306217: Sep  3 12:25:26.450: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(0/0), Late col
lision
306218: Sep  3 12:25:26.762: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(0/0), Late col
lision
306219: Sep  3 12:25:27.394: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(0/0), Late col
lision
306220: Sep  3 12:25:28.026: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(0/0), Late col
lision
306221: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI :
SIPSPI_EV_CC_CALL_DISCONNECT
306222: //2136/39D8F726930D/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:599@80.0.0.9:56150;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 192.168.1.1:5060;branch=z9hG4bK4B658
To: "amin" <sip:599@192.168.1.1>;tag=du3j9gb16-nEFTzLJiAqxQ7UOxWyH58t
Date: Mon, 03 Sep 2012 12:25:19 GMT
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1346675129
CSeq: 101 BYE
Reason: Q.850;cause=16
Content-Length: 0
306223: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList: via branch list is:
306224: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList:     end of list
306225: //2136/39D8F726930D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 192.168.1.1:5060;received=192.168.1.1;branch=z9hG4bK4B658;alias
CSeq: 101 BYE
Content-Length:  0
306226: //2136/39D8F726930D/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
306227: //2136/39D8F726930D/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
306228: //2136/39D8F726930D/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
682
