Xcode ressource behind firewall, what ports to permit
Hi all,
I install a gateway 2821 to have a XCODE ressources, the gateway will be behind a firewall, anybody know please what ports must be permit in the firewall ? is the IP Phones witch will use the transcoder sessions communicate with the gateway directly with rtp for example or just with the callmanager ?
Momo
Re: Xcode ressource behind firewall, what ports to permit
Hi!
RTP media will be established between endpoints, CUCM will be in charge of the signaling and to see where to route the call and which
meida resources to engage if needed/applicable. Therefore, gateways and media resources will handle RTP streams.
You'll need to open RTP ports or you can use an ACL.
"Unlike an ACL, most firewall configurations will open only the RTP stream port that Unified CM has told the phone and the gateway to
use between those two devices as long as the signaling goes through the firewall. "
You can check the SRND Voice security chapter for more information:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/security.html
Hope this helps!
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
Thank you Teresa for you answer, it helps very well.
an IPCC server will use the XCODE hardware ressources, i want to know please if that the IPCC server communicate RTP directly with the Gateway or that the CTI Route point that do it.
Best Regards,
Mohamed
Hi!
If you refer to the UCCX SNRD you'll see that the RTP stream is established between the CTI port and the GW.
(Please check page 42 for a detailed call flow example/explanation)
"The Accept step in the application will answer the call by sending a message to Cisco Unified CM to establish an
RTP stream between the selected CTI Port and the Voice Gateway (VG) port (or calling IP Phone)"
www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/design/guide/uccx70srnd.pdf
Have a nice day!
Teresa.
thanks a lot Teresa.
Momo
675
