07-23-2013 12:17 PM - edited 03-16-2019 06:30 PM
we used to have a 2811 with Xmedius version 6.x something that work 100% fine !
We need to upgrade to a 2911, the SagemCOM / Xmedius Cie, told us to upgrade to version 7 and to patch it with XMFSP-7.0.0.339-XMFaxDriverT38-HotFix.
With the 2911 and Xmedius v7 we are able to do inbound fax ( PSTN ---> 2911 ---> Xmedius ) it's working fine.
But we can't do outbound fax ( Xmedius ----> 2911 ---> PSTN )
I was wondering if anyone had a similar issue.
Thanks !
---- here is more information ----
config attatch
note : from Xmedius I know it add a 777 digit before the oudbound number so if you fax 5145551212 it will do 7775145551212.
The dial-peer are made for that.. but still outbound doesnt work.
Anyone ?
07-23-2013 12:41 PM
Philippe,
What release version of IOS were you running on the 2811?
Yosh
07-23-2013 12:56 PM
2811 IOS 12.4(24)T1 with Xmedius v6 = 100% working.
2911 IOS 15.2(4) with Xmedius v7 = Only inbound working.
... I saw some people that have similar problem and they fix that with fax-relay sg3-to-g3 but I am not so sure..
07-23-2013 01:11 PM
Philippe,
I know you haven't ran any debugs, but I'm curious to see if your issue is related to IOS 15. IOS 15 introduced toll prevention for h323 and sip. You can disable this by doing the following:
Voip service voip
No ip address trusted authenticate
Let me know if this helps
Yosh
07-25-2013 07:48 AM
the Call Manager ( Pub & SUB ) and the Fax server IP are all in the trust list under the voip service allready, so I don't suspect this issue.
thanks,
07-29-2013 01:16 PM
Here is what fix our problem :
IN GLOBAL CONFIG :
voice service voip
fax protocol t38 nse version 3 ls-redundancy 0 hs-redundancy 2 fallback pass-through g711ulaw
IN ALL DIALPEER TO FAX :
dial-peer voice 1142122 voip
fax protocol t38 version 3 ls-redundancy 0 hs-redundancy 2 fallback pass-through g711ulaw
