Community Member
XML[4]:Parse error
Hi all,
I've got an error on cucme 2811 router.
SW ver is - 12.4(22)YB / CME 7.1
There are more than 30 names (42 exactly) in the directory at my cucme router....
And if I try to view all names at phone's display, then error appears (XML[4]:Parse error).
If I deleting some names, then error disappears.
Is there anyone who met with same problems??
Re: XML[4]:Parse error
that usually is related to special characters being used, make sure you use only alphanumeric
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
I used only alphanumeric chatacters....
for example:
name Mzokov Vitaly
Maybe I have do it like this:
name "Mzokov Vitaly"
I checked all names, and no mistakes were found. If count of names is 30, then everything is good :)
Community Member
if user-locale is RU, than error exists...
if user-locale is US, than error does not exists..
Community Member
try to restart service Cisco Dialed Number Analyzer from Call Manager Server.
305
