Community Member
XML ERROR [4] : PARSE ERROR - Extension Mobility Call Manager 6.x
Hi All,
I have installed Call manager 6.0.1 and IP Communicator 7. Also I have configured Extension Mobility. While Login and Logout I am geeting XML ERROR [4] : PARSE ERROR.
The extension Mobility feature is working fine.
Could you please help me to address the issue.
Nirmal
1 ACCEPTED SOLUTION
Bronze
Re: XML ERROR [4] : PARSE ERROR - Extension Mobility Call Manage
First of upgrade your Cluster to a later version of Callmanager 6.1(4) something.There are alot of issues in the early version of the code which will cause you issues.To that first and i bet the issue will go away.
Cheers
Mark
1 REPLY
Bronze
Cheers
Mark
772
