xrule with tag <xx> doesn't exist , CME 7.0
Hi ,
have a small problem with the translation profile rule :
on cme 2801 do the following config.
voice translation-rule 81
rule 1 /^81/ //
voice translation-profile strip81
translate called 81
dial-peer voice 31 voip
translation-profile outgoing strip81
destination-pattern 81T
voice-class sip transport switch udp tcp
session protocol sipv2
session target ipv4:xxx.xxx.xxx.xxx
dtmf-relay sip-notify
when try to show te rule with "sh translation-rule" no rule exist .
There are someone with any idea ??
1 ACCEPTED SOLUTION
Re: xrule with tag <xx> doesn't exist , CME 7.0
Try "show voice translation-rule"
Hope that helped, if so please rate.
1 REPLY
182
