Yet Another Custom Background Image Problem....
Hi all,
I am now attempting to configure custom backgrounds on my 2811 router, which has phones consisting of 7971's, 7945's, 7975's, 7911's and 7941's. I have tried time and time again, and followed all guides, such as the one linked below, and still, just get "selections unavailable". Does anyone have a definate guide on how to accomplish this for multiple phone types without problems? (I have even used backgrounds.tar from Cisco's site, and still can't even get one of the standard Cisco images to appear, even though the xtract command sets it all up for me! (and yes I have been tftp-server flashing!
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-voice/366-cisco-ccme-ip-phone-background.html
I have been going around in circles for the last 3 hours trying to get ONE custom image to appear on any phone, and it's frustrating the **** out of me!
I have set the images to the required pixels and everything.
Can someone please help?
Nic.
1 ACCEPTED SOLUTION
Re: Yet Another Custom Background Image Problem....
Nic,
Try this:
tftp-server flash:/Desktops/320x216x16/List.xml alias Desktops/320x216x16/List.xml
Worked for me with a similar issue.
Best,
David
Super Bronze
Hi Nic
Basically you need to debug your tftp server, and watch what happens on the debug when you press buttons on the phone.
The process is basically:
You press the 'background' option
Phone requests the xml file
Phone parses the xml file and reads each thumbnail image from TFTP
You select an image
Phone downloads that image
If you are getting the selections unavailable, run debug tftp-server events on the router and ensure you are seeing the output (term mon etc)
Press backgrounds - you should see the phone attempt to get the XML file. If it fails, check your tftp server config
You should then see it grab the thumbnails - if you don't see this, it's likely your XML file is bad. Post it up here - any miscapitalisation or errors will simply not work.
Again, if you see errors downloading the thumbnails, your XML has been read OK, but the filenames are wrong or your TFTP server setup is not right.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aaron,
This is what I have so far.
Dir Flash Output, Desktops output, and the 320x216x16 Output for the 7975 as follows:
Router#dir flash:
Directory of flash:/
    1  drw-           0   Apr 1 2012 16:29:14 +10:00  GUI
   20  drw-           0   Apr 4 2012 13:23:02 +10:00  EA
   55  drw-           0   Apr 1 2012 15:23:54 +10:00  ATA
   57  -rw-      883261   Apr 2 2012 12:23:02 +10:00  MOH-POP.au
   58  drw-           0   Apr 6 2012 12:10:08 +10:00  Rings
   74  drw-           0  May 26 2012 22:42:30 +10:00  Desktops
  103  -rw-    64652888   Apr 1 2012 15:32:02 +10:00  c2800nm-adventerprisek9-mz.151-2.T1.bin
  104  drw-           0   Apr 1 2012 14:41:36 +10:00  Phones
Router#dir flash:Desktops
Directory of flash:/Desktops/
   85  drw-           0  May 26 2012 22:43:22 +10:00  320x216x16
  100  -rw-        4473  May 26 2012 22:44:44 +10:00  TN-OP-Color.png
  210  -rw-       42056  May 26 2012 22:45:28 +10:00  OP-Color-7975.png
  203  -rw-        2089  May 26 2012 22:46:14 +10:00  TN-Cisco-Color-7975.png
  101  -rw-        8156  May 26 2012 22:46:28 +10:00  Cisco-Color-7975.png
Router#dir flash:Desktops/320x216x16
Directory of flash:/Desktops/320x216x16/
   76  -rw-         245  May 27 2012 11:12:06 +10:00  List.xml
TFTP Server Flash Commands as follows:
tftp-server flash:/Desktops/OP-Color-7975.png
tftp-server flash:/Desktops/TN-OP-Color.png
tftp-server flash:/Desktops/Cisco-Color-7975.png
tftp-server flash:/Desktops/TN-Cisco-Color-7975.png
A copy of my List.xml File
URL="TFTP:Desktops/OP-Color-7975.png"/>
URL="TFTP:Desktops/Cisco-Color-7975.png"/>
And finally, an output of TFTP Debug
*May 27 01:26:03.626: TFTP: Looking for Desktops/320x216x16/List.xml
(That's all I get).
Any ideas?
Thank you!!
Nic.
Nic,
Try this:
Best,
David
David,
Thank you so, so, so, so much! Nailed it in one! You have no idea how frustrating this was!
Thanks again
Nic.
VIP Super Bronze
+5 for you David,
Excellent work!
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
712
