You Have VoiceMail on 7962
Hi Folks
I have a corporate Cisco IP 7962 and it is stating "You Have VoiceMail".
I login to Messages with my ID and the system states that I do not have any current or old
voicemail yet the handset MWI is red and the LCD screen has a flashing envelope and states "You Have VoiceMail"
Thx
Hi.Try to dial MWI/off
Hi.
Try to dial MWI/off directory number and the light should turn off.
Than leave a new message on your own Mailbox and listen to it and see if light works as expected.
Let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi CarloI left a new message,
Hi Carlo
I left a new message, listened to it then deleted it. This seems to have cleared the "You have VoiceMail" issue and the handset is not red anymore. A five Star answer. *****
Much appreciated
Thx Jim
Hi Jim.Glad that helped.If
Hi Jim.
Glad that helped.
If you want, you can mark this discussion as answered so that others can easily find a solution if they have a similar query.
Thanks again
Carlo
49
