08-28-2013 10:11 AM - edited 03-01-2019 05:41 PM
I'm looking for a quick-n-dirty of what needs to be allowed to pass through a firewall for DHCP6 to work. I know DHCP6 uses UDP546 on the client and UDP547 on the server. I also believe that there is some important ICMP traffic, but allowing all ipv6-icmp from the DHCP server isn't cutting the mustard. I have RFC 3315 open, but... well, it's an RFC, and my head is already hurting.
Specifically, I want to get this working with OSX 'Mountain Lion' and ip6fw.
08-28-2013 10:35 AM
I am not sure what icmp messages you were referring to. Allowing udp 546 to udp 547 and vice versa should suffice for dhcpv6 to work.
09-05-2013 05:37 AM
The ICMP messages you're talking about are for IPv6 ND features like NS/NA or RS/RA but not for DHCPv6.
Alain
09-05-2013 05:58 AM
Hi Alain,
These ICMPv6 messages are exchanged on the local subnet and will not traverse the FW unless it runs in transparent mode.
09-05-2013 07:45 AM
Hi Harold,
Yes you're correct I should have mentioned the mode had to be transparent, my bad.
Alain
