Allow DHCP6 through firewall?
I'm looking for a quick-n-dirty of what needs to be allowed to pass through a firewall for DHCP6 to work. I know DHCP6 uses UDP546 on the client and UDP547 on the server. I also believe that there is some important ICMP traffic, but allowing all ipv6-icmp from the DHCP server isn't cutting the mustard. I have RFC 3315 open, but... well, it's an RFC, and my head is already hurting.
Specifically, I want to get this working with OSX 'Mountain Lion' and ip6fw.
Everyone's tags (3)
I am not sure what icmp messages you were referring to. Allowing udp 546 to udp 547 and vice versa should suffice for dhcpv6 to work.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Purple
The ICMP messages you're talking about are for  IPv6 ND features like NS/NA or RS/RA but not for DHCPv6.
Alain
Hi Alain,
These ICMPv6 messages are exchanged on the local subnet and will not traverse the FW unless it runs in transparent mode.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Purple
Hi Harold,
Yes you're correct I should have mentioned the mode had to be transparent, my bad.
Alain
1857
