Cisco 867VAE IPv6 over PPPoA/PPPoE (IPV6CP)
Olivier Dijoux
my ISP is offering native IPv6 ADSL, so i get a brand new Cisco 867VAE ISR to do IPv6 over PPPoA/PPPoE, via IPV6CP
C867VAE (CISCO867VAE-K9) come with "ADVANCED SECURITY" level, IOS 15.1
system image file is "flash:c860vae-advsecurityk9-mz.151-4.M3.bin"
that's the highest license level, since "ADVANCED IP SERVICES" seems not available for 860VAE models
so i checked "Cisco Feature Navigator" where i can see that for platform Cisco 867VAE,
the following features are "available" :
IPv6 Access Services: PPPoA
IPv6 Access Services: PPPoE
but i'm afraid C867VAE, with IOS "ADVANCED SECURITY", doesn't support IPV6CP,
(and i see DHCPv6 is not present anyway), can someone help me to confirm ?
IPv4 is working fine, but no IPV6CP negotiation during PPP (see my config extract below)
"debug ppp nego" doesn't show any IPV6CP at all, only got this persistent error in show log :
000422: *Apr  6 07:28:21.817 CEST: Vi2 PPP: Outbound ipv6 packet dropped, NCP not negotiated
so can Cisco 867VAE really do IPv6 over PPPoA/PPPoE throughout IPV6CP ?
or did i forgot any command to activate/allow it ?
Thanks for you help
Olivier
relevant part of my configuration :
ipv6 unicast-routing
no ipv6 source-route
ipv6 cef
ipv6 route ::/0 Dialer0
interface ATM0.1 point-to-point
ip flow ingress
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Dialer0
ip address negotiated
ip access-group internet_in in
ip mtu 1452
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer-group 1
ipv6 address autoconfig
ipv6 enable
ppp authentication chap callin
ppp chap hostname xxx@isp.ipadsl
ppp chap password xxxxx
dialer-list 1 protocol ipv6 permit
Hi Olivier,
TAC have confirmed it's a bug and opened a new bug for this.
When this happens I ususally end up waiting 3 months + for a resolution, so if you want to see this move faster you'll need to open a TAC case also referencing bug
CSCua08876
-Scott
8 Replies 8
fb_webuser
Level 6
Level 6
From your output, the ipv6 packet is dropped outbound.
no input from debug ppp nego, so it doesn´t even try to negotiate.
try putting the interface as native ipv6, removing the acl, and ip address negotiated, you have ipv6 autoconfig.
your isp is offering native ipv6, not dual stack.
About the IOS, try upgrading for the latest release, like the 15.2(3)T, advanced security.
please if you fix it, i would like to know.
Posted by WebUser Pedro Seabra Ávila from Cisco Support Community App
Thanks, I tried,
also upgraded to latest IOS 15.2(3)T Advanced Security (c860vae-advsecurityk9-mz.152-3.T),
but still no IPV6CP at all in "debug ppp nego"
for now, i'll stay with my IPv6 Tunnel Broker ...
if someone know if PPP IPV6CP is possible (or not) on C867VAE ISR, please advise
Thanks for you help
Olivier
Scott Pettit
Level 9
Level 9
Hi Olivier,
I've done some testing and I can get an 887VA working fine with IPv6 (running IOS 15.1(4)M4).  If I use the identical configuration on 867VAE with IOS 15.1(4)M4 - it does not work.
I've logged a TAC case about this as it looks like a bug to me.
-Scott
Hi Scott,
thanks, please keep me informed when you got more info about your TAC case
best regards
Olivier
Hi Olivier,
CSCua08876
-Scott
I'm running into the same problem - but next to that it appears that there is also no way to do prefix-delegation as a client) on the box. The neccesary commands under the dialer interface are missing... "ipv6 dhcp pd " is not there, neither is "ipv6 dhcp pool <...>"
Nice box, but these features need to be added, any other 8xx box runs this just fine on 12.4.
Olivier Dijoux
an update to say that bug CSCua08876 is fixed in IOS release "15.1.4M5" released 06/Sep/2012
IPV6CP now working fine on C867VAE
now missing ipv6 dhcp pd ;-)
Olivier
IPv6 DHCP PD is working fine in :
Cisco IOS Software, C860 Software (C860VAE-ADVSECURITYK9-M), Version 15.2(4)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 27-Jul-12 02:47 by prod_rel_team
config:
interface XYZ
ipv6 dhcp client pd myprefix rapid-commit
