Community Member
Help with a 6RD Basic config!
Hi there,
I am trying to start a basic setup to demonstrate 6RD and I am in trouble for a few hours. I just found an excellent pdf on this site and I tried to use it to start something using the same config but I did not have any success for the ulimated "ping" test !
I am using a very simple and basci setup using a:
        CE ------ IP Router --------BR
This is my relevant config for the CE :
interface Loopback0
ip address 10.0.0.10 255.255.255.255
interface Tunnel0
no ip address
no ip redirects
ipv6 address 2001:DB80:A0A:100::/128
ipv6 rip fred enable
tunnel source Loopback0
tunnel mode ipv6ip 6rd
tunnel 6rd ipv4 prefix-len 16
tunnel 6rd prefix 2001:DB80::/32
tunnel 6rd br 10.0.0.1
ipv6 route 2001:DB80::/32 Tunnel0
And at the BR I got the following relevant info:
interface Tunnel0
no ip address
no ip redirects
This is my version:
P1R3#sh ver
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 15.1(3)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 10-Aug-11 03:46 by prod_rel_team
More info about tunnels and intf:
P1R3#sh tunn 6rd
Interface Tunnel0:
  Tunnel Source: 10.0.0.10
  6RD: Operational, V6 Prefix: 2001:DB80::/32
       V4 Prefix, Length: 16, Value: 10.0.0.0
       V4 Suffix, Length: 0, Value: 0.0.0.0
       Border Relay address: 10.0.0.1
  General Prefix: 2001:DB80:A::/48
P1R3#sh ipv6int tu0
% Invalid input detected at '^' marker.
P1R3#sh ipv6i nt tu0
*Oct 30 22:06:13.266: Tunnel0 count tx, adding 20 encap bytes
P1R3#sh ipv6 int tu0
Tunnel0 is up, line protocol is up
  IPv6 is enabled, link-local address is FE80::A00:A
  No Virtual link-local address(es):
  Global unicast address(es):
    2001:DB80:A0A:100::, subnet is 2001:DB80:A0A:100::/128
  Joined group address(es):
    FF02::1
    FF02::2
    FF02::9
    FF02::1:FF00:0
    FF02::1:FF00:A
  MTU is 1480 bytes
  ICMP error messages limited to one every 100 milliseconds
  ICMP redirects are enabled
  ICMP unreachables are sent
  Post_Encap features: Tunnel 6RD
  ND DAD is not supported
  ND reachable time is 30000 milliseconds (using 30000)
  Hosts use stateless autoconfig for addresses.
P1R3#
1R3#
*Oct 30 22:08:40.146: Tunnel0 count tx, adding 20 encap bytes
P1R3#show ipv6 route
IPv6 Routing Table - default - 5 entries
Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
       B - BGP, HA - Home Agent, MR - Mobile Router, R - RIP
       I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary
       D - EIGRP, EX - EIGRP external, ND - Neighbor Discovery
       O - OSPF Intra, OI - OSPF Inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
       ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
C   2001:DB8:BAD:F00D::/64 [0/0]
     via FastEthernet0/0, directly connected
L   2001:DB8:BAD:F00D::1/128 [0/0]
     via FastEthernet0/0, receive
S   2001:DB80::/32 [1/0]
     via Tunnel0, directly connected
LC  2001:DB80:A0A:100::/128 [0/0]
     via Tunnel0, receive
L   FF00::/8 [0/0]
     via Null0, receive
P1R3#
*Oct 30 22:09:07.226: Tunnel0 count tx, adding 20 encap bytes
P1R3#
P1R2#show ipv6 route
LC  2001:DB8:CAFE:1::1:2/128 [0/0]
     via Loopback0, receive
C   2001:DB80:6400:FECA::/64 [0/0]
     via Loopback99, directly connected
L   2001:DB80:6400:FECA:CACA::1/128 [0/0]
     via Loopback99, receive
LC  2020:1:1:1::1/128 [0/0]
L   FF00::/8 [0/0]
     via Null0, receive
P1R2#
Sending on one side:
Sending 5, 100-byte ICMP Echos to 2020:1:1:1::1, timeout is 2 seconds:
Packet sent with a source address of 2001:DB8:BAD:F00D::1
*Oct 30 22:12:28.318: Tunnel0 count tx, adding 20 encap bytes
*Oct 30 22:12:28.958: ICMPv6: Sent echo request, Src=2001:DB8:BAD:F00D::1, Dst=2020:1:1:1::1.
*Oct 30 22:12:30.958: ICMPv6: Sent echo request, Src=2001:DB8:BAD:F00D::1, Dst=2020:1:1:1::1.
*Oct 30 22:12:32.958: ICMPv6: Sent echo request, Src=2001:DB8:BAD:F00D::1, Dst=2020:1:1:1::1.
*Oct 30 22:12:34.958: ICMPv6: Sent echo request, Src=2001:DB8:BAD:F00D::1, Dst=2020:1:1:1::1.
*Oct 30 22:12:36.958: ICMPv6: Sent echo request, Src=2001:DB8:BAD:F00D::1, Dst=2020:1:1:1::1.
Success rate is 0 percent (0/5)
P1R3#
Does not show up on the other side:
P1R2#deb ipv6 icmp
  ICMP Packet debugging is on
P1R2#
Any idea of something missing or wrong ?
Setups can be accessed remotely...
TIA
Fred
Bonjour Frédéric,
You are trying to ping an address outside the 6RD domain so you need to configure a default route on the CE as follow.
ipv6 route ::/0 2001:db80:1::0
Note that the next hop address incorporates the last 16 bits of the BR ipv4 address.
P.S.: the "tunnel 6rd br" command is not used to indicate the default gateway to exit the 6RD domain. it is simply configured so the CE can accept a different IPv4 source address than the embedded source address when packets come from outside the 6RD domain.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
BTW, I just noticed that the IPv6 address on the CE tunnel interface, uses 0xA0A as the embedded ipv4 address. This does not correspond to the last 16 bits (since you use a 16 bits ipv4 prefix length) of the local ipv4 address (10.0.0.10). This should be fixed as well.
Also, you do not absolutely need an IPv6 address on the tunnel interface but you should at least configure "ipv6 enable" on the tunnel interface on the BR.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
Re: Help with a 6RD Basic config!
thank you harold!
actually I did this lab after a few nights and days with almost no sleep to prepare a nice new training I have developped from an existing CISCO training
The first sessions are for you (cisco) ;-) and I wanted it to be perfect...
I was sure to have done some BIG mistakes that I would have discover after a good night sleep ;-)
The first session is currently running this week.
I am going to try again tonight so maybe I will show this to my students tomorrow
http://www.fastlaneus.com/course/fl-ipv6spse
Great to hear that you have put an advanced IPv6 training together. I look at the class description and looks promising. Good IPv6 classes are kind of rare these days. I will definitely recommend that class to some of my customers. Do not hesitate to let me know if you come across any issue with your testing.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
Thank you very much!
Community Member
you are sure about
::0 This is weird.. no ?
Hi Fred,
Well, 2001:db80:1::0 or 2001:db80:1:: would do. Only the first 48 bits are important here (32 bits 6rd ipv6 prefix + 16 bits embedded ipv4 suffix). The CE extracts the embedded ipv4 suffix, adds it to the local prefix (derived from the tunnel source) and use the result as the destination ipv4 address to forward packets to the BR.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
1526
