04-30-2012 01:18 PM - edited 03-01-2019 05:34 PM
As we begin deployment IPV6 we are going to be in a mixed IPV4/6 environment - we have required access lists implemented for IPV4 and must applty the same ACL defined for for IPV6. Is it possible to apply IPV4 and IPV6 access lists concurrently on an interface or is a single access list containing both IPV4 and IPV6 addresses called for?
Solved! Go to Solution.
05-01-2012 07:36 PM
You will need to have concurrent ACLs applied to an interface.
The access lists are address familiy specific in their syntax and features so they cannot be mixed. An indicative example is shown below.
interface Ethernet1/1
ip access-group test-v4 in
ipv6 traffic-filter test-v6 in
ip access-list extended test-v4
permit ip any host 1.1.1.1
deny ip any any
ipv6 access-list test-v6
permit ipv6 any host 2001:DB8::1
deny ipv6 any any
05-01-2012 07:36 PM
deny ip any any
deny ipv6 any any
05-02-2012 05:20 AM
Thanks that was what I was looking for as I was worried about having two inbound access lists applied to the same interface
