IPv6 is stalled
Hi all,
I've just configured an IPv6 address in two interfaces of two different routers connected to the same vlan.
The thing is that I can't ping each other and I see this "IPv6 is stalled" message that seems to be the cause of the problem.  I first thought that it had to do with the link-local address so I configured a new one manually. Sadly the problem still exist.
The funny thing is that the same two routers are also connected through another different vlan, with IPv6 addresses configured in it and it works fine in this different vlan.  Any hint about what might be going on??
ROUTESP02#sh ipv6 interface vlan 12
Vlan12 is up, line protocol is up
  IPv6 is stalled, link-local address is FE80::21E:13FF:FEE4:B3C0 [DUP]
  No Virtual link-local address(es):
  Description:
  Global unicast address(es):
    2001:7F8:1::40, subnet is 2001:7F8:1::/64 [TEN]
  Joined group address(es):
    FF02::1
    FF02::2
  MTU is 1500 bytes
  ICMP error messages limited to one every 100 milliseconds
  ICMP redirects are enabled
  ICMP unreachables are sent
  Post_Encap features: HW shortcut
  ND DAD is enabled, number of DAD attempts: 1
  ND reachable time is 30000 milliseconds (using 30000)
  ND advertised reachable time is 0 (unspecified)
  ND advertised retransmit interval is 0 (unspecified)
  ND router advertisements are sent every 200 seconds
  ND router advertisements live for 1800 seconds
  ND advertised default router preference is Medium
  Hosts use stateless autoconfig for addresses. ROUTESP02#sh ipv6 interface vlan 12
  Description: RED NODAL ESPANIX - LAN ALTA MAD1GSW4-puerto 6/10 - publica
    FF02::1
    FF02::2
  MTU is 1500 bytes
Cheers!
Floren
1 REPLY
IPv6 is stalled
These are the things that upset me the most.
I concluded that since this router is in a peering point (Espanix) someone had to be using my link-local address so I tried to change it several times.
  ROUTESP02(config-if)#ipv6 address FE80::69 link-local
   Mar 15 19:40:26.520: %IPV6_ND-4-DUPLICATE: Duplicate address FE80::69 on Vlan12
ROUTESP02(config-if)#ipv6 address FE80::1276 link-local
Mar 15 19:41:23.884: %IPV6_ND-4-DUPLICATE: Duplicate address FE80::1276 on Vlan12
After that I issued the command ipv6 nd dad attempts 0 and everything worked fine.
So it was clear that the problems was ND related.  I activated the following debug: "debug ipv6 nd"  and roll the config back to ipv6 nd dad 1 ( by default).
Looking at the debug messages everything seemed to work so I run the show ipv6 interface vlan 12 command again and ..... now it was Ok!!!!
ROUTESP02#sho ipv6 inter vlan 12
  IPv6 is enabled, link-local address is FE80::21E:13FF:FEE4:B3C0 ROUTESP02#sho ipv6 inter vlan 12
The problem is solved and i don't know what happened.
2817
