Anyconnect Jabber for iPhone issue
We have Anyconnect setup to automatically launch when we open the Jabber voice client on our iPhones.  For the most part it works fine.  The issue we're running into is with connecting to voicemail and to the directory.  If we launch Jabber and let anyconnect launch automatically, it takes a minute for the directory to connect and about 8 to 10 minutes for voicemail to connect.  If we establish the VPN first and then open Jabber, everything will connect instantly.  Has anyone else had this issue or have any ideas.
Everyone's tags (1)
1 REPLY
If you are using IP addresses
If you are using IP addresses instead of FQDN, this could happen.  Are the On Demand domain settings correct?  If you're using a filter, make sure the CRL for the target server is accessible because that will cause a huge delay.
96
