Application dial rule to remove ( ), - symbols
Aware of the application dial rule can remove + symbol, but can it remove the ( ) and - symbols as well ?
T.C.
1 REPLY
the best information that i
the best information that i could find related to this query; was in the following link; http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/bccm-861-cm/b03adial.html
this is for cucm ver 8.6.1; and the only permissible characters that are possible are;
Number Begins With
Enter the initial digits of the directory numbers to which you want to apply this application dial rule.
Valid characters include numeric digits (0-9), plus sign (+), asterisk (*), and number sign (#). Be aware that you cannot enter more than 50 characters in this field.
() and - are not treated as permissible entries as per this link.
As far as i see it this has not changed even in version 10.x; here is the link to refer ;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmcfg/CUCM_BK_C95ABA82_00_admin-guide-100/CUCM_BK_C95ABA82_00_admin-guide-100_chapter_011101.html
- please rate if this helps.
164
