Availible tokens in custom embedded tabs
Hi all,
For a custom embedded tab we want to add call variables in a URL.
From cisco documentation:
The following is an example of how you can use the ${UserID} token:
1 You specify the following in your custom embedded tab:
<url>www.cisco.com/${UserID}/profile</url>
Are there other tokens availible to add to this URL? For example called number and calling line ID?
Thanks!
Wouter
Everyone's tags (2)
wouter were you able to get
wouter were you able to get the value in the token ${UserID}? I do not get any value in place of the token, it remains blank.
Yogesh
were you able to find other
were you able to find other tokens? I need also to find the called number (myNumber)
When there is an incoming call I can get this information in the event:
function OnTelephonyConversationStateChanged(json) {
var conversation = JSON.parse(json);
var myNumber=conversation.localParticipant.translatedNumber;
var incomingNumber=conversation.remoteParticipants[0].translatedNumber;
but when there is not an incoming call I don't know how to get it. It could be interesting to have something like ${translatedNumber} or similar
 I used 'Cisco Jabber 11.0
 I used 'Cisco Jabber 11.0 Deployment and Installation Guide' and creted a custom tab.
Plugin info:
  <browser-plugin>    <page refresh="true" preload="false">     <tooltip>Weiterleitung KSC</tooltip>     <icon/>     <url>http://XXXX/LasttestGUI/index.jsp</url>    </page>   </browser-plugin>
<html>
<head>
<meta charset="utf-8">
<meta http-equiv="Cache-Control" content="no-cache">
<title>CTI Test</title>
<script type="text/javascript">
var myDiv = document.getElementById("ctilog");
try {
myDiv.innerHTML += "State: " + conversation.state + "<br/>";
myDiv.innerHTML += "Acceptance: " + conversation.acceptanceState + "<br/>";
myDiv.innerHTML += "Type: " + conversation.callType + "<br/>";
myDiv.innerHTML += "<br/>";
catch(e) {
myDiv.innerHTML += "cannot parse conversation:: " + e.message + "<br/>";
if (conversation.acceptanceState == "Pending" && conversation.state == "Started") {
myDiv.innerHTML += "About to screen pop<br/>";
int anzahlErkanntenTel = conversation.remoteParticipants.length;
if (anzahlErkanntenTel == 0) {
window.open("http://mitarbeiterportal-np/");
} else {
for (var i=0; i<conversation.remoteParticipants.length; i++) {
myDiv.innerHTML += "Popping with number: " + conversation.remoteParticipants[i].translatedNumber + '<br/>';
</script>
</head>
<body>
<h4>CTI Log Try</h4>
<div id="ctilog"></div>
</body>
</html>
I see the CTI Log Try Screen. But the page doesn't write the log.
What I do wrong?
Thanks in advance.
298
